[mesh manipulation] Exporting OpenFoam multiregion mesh to Fluent
Like Tree1Likes
  • 1 Post By khalil.bmch
Old   February 9, 2022, 15:15
Question Exporting OpenFoam multiregion mesh to Fluent
khalil
khalil.bmch is on a distinguished road
Hello Everyone,
I have generated a .unv Mesh with Salome which is basically just two cubes of different materials sharing an interface.
I want to use Fluent as a solver to solve for heat transfer. So I used OpenFoam to convert my .unv file to openfoam’s format using "ideasUnvtoFoam", after that I usually use "foamMeshtoFluent" command and everything works fine. Except that this time I need two "cell zones" in Fluent to assign 2 different materials and this method only generates one cell zone.
I then used the OpenFoam command "splitMeshRegions -cellzones -overwrite” to split the domain and the resulting mesh was indeed split when I visualize it in Paraview, but the problem remains when it comes to reading it in Fluent, still one cell zone.
I hope someone can help, thank you.
enrico_agostini likes this.
khalil.bmch is offline   Reply With Quote
Old   August 2, 2022, 10:52
Default follow up
Enrico Agostini
enrico_agostini is on a distinguished road
Hi Khalil, do you have any news? I want to do something similar, but using simply snappyHexMesh. Did you find any solution that works?
enrico_agostini is offline   Reply With Quote
Old   August 2, 2022, 14:33
khalil
Hello Enrico,
I solved this problem by generating as many meshes as cell zones, then appending them successively in Ansys Fluent.
So you have to import the first mesh (corresponding to your first region), then append the second one to it. Doing so generates a new cell zone in Fluent. Just don't forget to correctly configure the interface and you're good to go !
fluent, foammeshtofluent, openfoam, salome, splitmeshregions
[Other] [Request] OpenFOAM mesh to 2D Ansys fluent mesh anon_q OpenFOAM Community Contributions 6 July 3, 2023 05:24
Exporting mesh from Fluent mech_sim FLUENT 2 December 20, 2021 10:30
Exporting Fluent adjoint boundary mesh as .stl or parasolid. _11_ FLUENT 1 April 1, 2020 01:22
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 03:41
