[mesh manipulation] topoSet produces less cells than expected |
March 18, 2022, 08:13 |
Giacomo
Rep Power: 4 |
Hello there,
I'm using topoSet to define a cellSet in which I'd like to apply trip later on. I've created a 2D mesh in ICEM, so I run Code:
fluentMeshToFoam Code:
topoSet Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 21.06 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object faceSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name tripSet; action new; type cellSet; source rotatedBoxToCell; sourceInfo { origin (0.09977 0.05577 -0.5); i (4.93029e-3 1.09302e-3 0); j (-1.29864e-4 5.85778e-4 0); k (0 0 0.5); } } ); The problem is that topoSet just select some random cells and not all the cells inside the rectangle. The same code works for the LES 3d case (which is the second image), but when I apply it to the 2D RANS, it gives me this random output (first image). I don't understand what I'm missing. At the beginning I thought that it was a problem due to the definiton of RANS's patch Code:
frontAndBackPlanes empty Code:
left Code:
right Code:
cyclic If anybody might have a clue or a hint to give it to me, it'd be very appreciated. Below you can find the Code:
checkMesh Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Mesh stats points: 942026 internal points: 0 faces: 1874296 internal faces: 932270 cells: 467761 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 467761 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology OUTLET 266 534 ok (non-closed singly connected) INLET 3517 7036 ok (non-closed singly connected) SS 1361 2724 ok (non-closed singly connected) PS 1360 2722 ok (non-closed singly connected) front 467761 471013 ok (non-closed singly connected) back 467761 471013 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox tripSet 34 128 6.40191e-07 (0.0997363 0.0558234 -0.180277) (0.104675 0.0573815 0.180277) Checking geometry... Overall domain bounding box (-4.99999 -5 -0.180277) (10 5 0.180277) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-1.24833e-17 2.34241e-17 -8.11459e-15) OK. Max cell openness = 4.27054e-15 OK. Max aspect ratio = 83.5961 OK. Minimum face area = 1.49745e-08. Maximum face area = 0.0510004. Face area magnitudes OK. Min volume = 5.39913e-09. Max volume = 0.00176845. Total volume = 50.1848. Cell volumes OK. Mesh non-orthogonality Max: 62.4138 average: 22.3492 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.11943 OK. Coupled point location match (average 0) OK. Mesh OK. End Last edited by gisc; March 21, 2022 at 12:10. Reason: typos |
March 21, 2022, 12:04 |
[UPDATED] topoSet produces less cells than expected
Giacomo
Rep Power: 4 |
I have managed to find a workaround to the issue.
By splitting the frontAndBackPlanes patch in front an back patches (which are still defined as empty), and extruding the mesh in the z direction for 1 layer, the aforementioned problem doesn't seem to happen anymore, and the resulting output is exactly the one of the second image in the previous post. I still doesn't understand what that issue was due to, therefore if anybody might have a clue it'd be very nice! Below my workaround and checkMesh code for reference. topoSet: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 21.06 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object faceSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { // Set of faces corresponding to the front and back patches name right; action new; type faceSet; source patchToFace; patch frontAndBackPlanes; } { // Setof faces within a thin box at the left boundary name left; action new; type faceSet; source boxToFace; sourceInfo { box (-1000 -1000 -1) (1000 1000 -0.17); } } { // Intersect left with right name left; action subset; type faceSet; source faceToFace; sourceInfo { set right; } } { // Delete left part from right name right; action delete; type faceSet; source faceToFace; sourceInfo { set left; } } ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // pointSync false; patches ( { // Name of new patch name front; // Type of new patch patchInfo { type empty; } // How to construct: either from 'patches' or 'set' constructFrom set; // If constructFrom = patches : names of patches. Wildcards allowed. set right; } { // Name of new patch name back; // Type of new patch patchInfo { type empty; } // How to construct: either from 'patches' or 'set' constructFrom set; // If constructFrom = patches : names of patches. Wildcards allowed. set left; } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object extrudeMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // What to extrude: // patch : from patch of another case ('sourceCase') // mesh : as above but with original case included // surface : from externally read surface constructFrom patch; sourceCase "./"; sourcePatches (back); // If construct from patch: patch to use for back (can be same as sourcePatch) exposedPatchName front; // Flip surface normals before usage. Valid only for extrude from surface or // patch. flipNormals false; //- Linear extrusion in point-normal direction extrudeModel linearNormal; nLayers 1; expansionRatio 1.0; linearNormalCoeffs { thickness 0.05; } // Do front and back need to be merged? Usually only makes sense for 360 // degree wedges. mergeFaces false; //true; // Merge small edges. Fraction of bounding box. mergeTol 0; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Mesh stats points: 942026 internal points: 0 faces: 1874296 internal faces: 932270 cells: 467761 faces per cell: 6 boundary patches: 7 point zones: 1 face zones: 7 cell zones: 4 Overall number of cells of each type: hexahedra: 467761 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology OUTLET 266 534 ok (non-closed singly connected) INLET 3517 7036 ok (non-closed singly connected) SS 743 1490 ok (non-closed singly connected) PS 1360 2722 ok (non-closed singly connected) front 467761 471013 ok (non-closed singly connected) back 467761 471013 ok (non-closed singly connected) controlSuction 618 1238 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology SScontrolFace 618 1238 ok (non-closed singly connected) SSfaces 743 1490 ok (non-closed singly connected) wall 0 0 ok (empty) SSnoSlipFaces 0 0 ok (empty) SScontrolFacezone 65041 33856 multiply connected (shared edge) SScontrolFaces 0 0 ok (empty) wallFace 0 0 ok (empty) <<Writing 33728 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox wallCell 1361 5448 5.07231e-06 (-0.000180697 -0.0871557 -0.230277) (0.996249 0.07202 -0.180277) SScontrolCell 15626 32618 0.000294549 (0.252503 -0.037306 -0.230277) (0.857067 0.0948286 -0.180277) SScontrolCellzone 0 0 0 (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) tripSet 50 132 1.31013e-07 (0.0997363 0.0558234 -0.230277) (0.104675 0.0573815 -0.180277) Checking geometry... Overall domain bounding box (-4.99999 -5 -0.230277) (10 5 -0.180277) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (4.17261e-19 7.20212e-18 -5.28938e-15) OK. Max cell openness = 5.45454e-15 OK. Max aspect ratio = 83.6515 OK. Minimum face area = 1.49638e-08. Maximum face area = 0.00707244. Face area magnitudes OK. Min volume = 7.48189e-10. Max volume = 0.000245248. Total volume = 6.95939. Cell volumes OK. Mesh non-orthogonality Max: 66.9894 average: 22.36 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.11933 OK. Coupled point location match (average 0) OK. Mesh OK. End Last edited by gisc; March 21, 2022 at 12:09. Reason: typos |
#cellset, #openfoam, #rotatedboxtocell, #toposet, #tripping |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
