June 21, 2022, 08:01 |
Wood Combustion in openFoam
Hi all, I am trying to simulate wood combustion in a wood stove using openfoam and salome
i keep on ending up in error when i try to convert using ideasUNVToFoam My doubts: 1. How to place a volume inside of a volume for openfoam Firefoam simulation 2. Can i use snapply hexmesh instead of salome for meshing ? if so is .stl files alone enough ? 3. I am confused about the geometry and mesh setup for openfoam firefoam, i tried, panel region method and just the surface method |
June 21, 2022, 23:10 |
Hello Ponnusamy, I'm not sure about the error you are facing, but that should be solvable.
And as you mentioned, firefoam is the base solver for solid combustion and pyrolysis. Thank you |
June 22, 2022, 06:03 |
My doubt is, if you see from the image attached I have 2-volumes, A wood stove, and a wood log inside it. Do i have to cut out the volume where the wood is or can i have full stive volume and wood inside of it without removing the wood shape in stove geometry,
Also for snappyhexmesh will the mesh intersect eachother ? I have never used snappyhexmesh before for this type of conditions |
June 22, 2022, 09:13 |
I haven't used snappyhexamesh either.
Try simulating your model with one volume in the beginning stage. If possible go with 2D case and slowly give a progress |
June 28, 2022, 16:21 |
priamas
I haven't used snappyhexamesh too ;(
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
Doubts Regarding Performing Combustion Simulation in OpenFoam | DineshMyilsamy | OpenFOAM Pre-Processing | 0 | June 26, 2018 07:39 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM combustion example | Benzaa | Main CFD Forum | 0 | April 1, 2009 10:23 |
combustion of wood | Özer AYDIN | FLUENT | 4 | June 25, 2007 03:11 |
