[snappyHexMesh] Layers collapsing when blockMesh used for overall refinement |
June 24, 2022, 12:00 |
Vergas Jairo
I have a mesh with 15k cells and a layer around a blade, with extrusion for wall function turbulence model application, so ideally wouldn't want to change that layer thickness. I want to increase overall mesh refinement of the pump with the blades to check for mesh sensitivity, but as I increase the blockMesh dict refinement, the layers around the blade collapse as shown in the figure below.
Why does this happen, and what can I do to refine the overall mesh without this happening? Thank you |
June 26, 2022, 07:11 |
M
Rep Power: 12 |
A) collapsing layers is a big problem with sHM, search this forum to find some recommendations, there are a lot
B) Your first cell height is ~1/4 of the blade thickness? I would strongly doubt that as a yplus requirement. Make sure you calculated it correctly. |
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box | noodleluvmay | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2020 10:55 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
