[Gmsh] Mesh a truncated cone with prism layers |
June 27, 2022, 17:09 |
Rep Power: 3 |
Hello to all,
I would like to mesh a cone with hexahedral mesh. The idea is to have a unstructured mesh on the top and bottom and "prism" (hexahedral) throughout the height. I am able to generate what I want in 2D mesh (script attached), but when I go to 3D it will generate tetras instead of hexas. I do know know how to solve this, and would appreciate some help. Is it possible to extrude a mesh with an angle? Kind Regards cone.zip |
June 28, 2022, 04:29 |
Not sure.
Does classy_blocks help here https://github.com/damogranlabs/classy_blocks Classy_blocks supports truncated cone (frustrum) as building block https://github.com/damogranlabs/clas...ape/frustum.py |
June 28, 2022, 04:44 |
#3 | |
Rep Power: 3 |
Hello Mr. Dlahaye, Thank you for the alternative. But I would really like it to be made inside gmsh environment. This part will connect to another geometry (which I have already drawn inside gmsh). I have drawn the truncated cone with a structured mesh, but would also like to have it with an unstructured one. However, if I let it generate tetras the mesh metrics will not be good. And I would like to create "prisms", i.e generate non-structured mesh for a circle and extrude it at an angle/ or generate the two circles, connect them and ask to generate the mesh (as in the attached script). I get the 2D outline but cannot get the 3D mesh as I want it. |
Number of prism layers mesh study | mtheory | STAR-CCM+ | 2 | August 14, 2021 06:49 |
Mesh Bias Factor , Prism Layers | Elsarraj_11 | STAR-CCM+ | 0 | April 7, 2021 14:01 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Mesh with Prism Layers | mdgowhar | SU2 | 3 | March 20, 2014 09:36 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
