[blockMesh] pipe through solid for chtMultiRegionSimpleFoam |
July 7, 2022, 04:37 |
Rep Power: 14 |
i started working with chtMultiRegionSimpleFoam. For that i need to mesh the attached geometry with blockMesh. I am used to mesh pipes with blockMesh. But now i need a box (the solid for chtMultiRegionSimpleFoam) around the pipe. Through the pipe flows some fluid, so there has to be a inlet and outlet. How to get startet? Any hints? i can mesh a solid with blockMesh und subtracst with topoSet the pipe, but how do i create the pipe then and the patches? |
July 7, 2022, 06:12 |
Al Csc
Rep Power: 7 |
In windshieldDefrost tutorial (of2206) there is most of the stuff you need. If you want to name a patch, topoSet and createPatch do the job
Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model | Dingens | FLUENT | 0 | July 9, 2021 06:19 |
temperature correction limited- Star ccm+ | LpSingh | STAR-CCM+ | 15 | September 29, 2020 11:06 |
Gas solid counter-current flow in a horizontal pipe | abc197 | Fluent Multiphase | 0 | July 30, 2020 18:16 |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
[blockMesh] 3D laminar flow in a pipe with a solid object inside | clint | OpenFOAM Meshing & Mesh Conversion | 1 | November 28, 2016 12:45 |
