[mesh manipulation] failed to impose cyclic BCs |
July 26, 2022, 12:45 |
Rep Power: 16 |
Dear all,
I am trying to run a channel LES simulation. The channel mesh is generated by gmsh. the front and back are defined as periodic BCs. First I define the cyclic directly in boundary file, but the output shows wrong, as you can see the result. Then I created the cyclic boundary using createPatch, and I have a new boundary file. However the results still not periodic. I am using v2112. Thanks! hewei /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "0.01/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 5 ( inlet { type patch; physicalType patch; nFaces 120; startFace 15090; } topAndBottom { type patch; physicalType patch; nFaces 900; startFace 15210; } outlet { type patch; physicalType patch; nFaces 120; startFace 16110; } front { type cyclic; inGroups 1(cyclic); nFaces 540; startFace 16230; matchTolerance 0.001; transform unknown; neighbourPatch back; } back { type cyclic; inGroups 1(cyclic); nFaces 540; startFace 16770; matchTolerance 0.001; transform unknown; neighbourPatch front; } ) // ************************************************** *********************** // |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
simpleFoam with cyclic BCs | Ria | OpenFOAM | 4 | October 21, 2013 09:28 |
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow | florian_krause | OpenFOAM | 3 | December 1, 2012 04:11 |
cyclic patch and other BCs | zxj160 | OpenFOAM | 0 | June 29, 2012 12:11 |
[mesh manipulation] Trying to build cyclic BCs on internal faces | DrDan | OpenFOAM Meshing & Mesh Conversion | 1 | March 15, 2012 23:38 |
