[snappyHexMesh] foam-extend 4.1 --- surfaceFeatureExtract |
July 27, 2022, 08:23 |
Wolfram Schneider
Rep Power: 8 |
Dear all,
I familiarise myself with the communty driven version foam-extend of OpenFoam in order to utilise the turbomachinery features like mixing plane and so ... Meshing with Salome for example works fine, but the workflow with snappyHexMesh seems to be different? I am not capable to make use of surfaceFeatureExtract. It is completely ignoring the according surfaceFeatureExtractDict. When using it "manually" with "surfaceFeatureExtract -includedAngle 150 ../../xx.stl ../../xx.eMesh" some files are created, but they can not be read by sHM.. Could anyone explain how to apply sHM in fe4.1? My issue with these .eMesh-files is that sharp edges are not meshed sufficiently. Best wishes |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
