[snappyHexMesh] How to force cells to snap and adapt to a line contained in the domain? |
September 16, 2022, 13:22 |
Rep Power: 4 |
Hello friends,
I am trying to create a rectangular mesh consisting of mostly rectangular cells. A wavy line is placed inside the mesh and I want the cells to mesh and refine along that. To give you a better understanding, I attached two screenshots. The first one simply shows us the rectangular mesh. It has a certain resolution in the xy-plane and only one cell in the z-direction resulting in a 3D box shape (do people call this 2.5D?). The second screenshot shows us the box but in wireframe representation. The mentionend "line" is also visible, but since we operate in 3D, the line is actually a surface (not a solid, not a volume, just a surface), which is stored in an STL-file created with gmsh. My idea was to use snappyHexMesh to force the line into the mesh and make the cells snap to it and refine the area around the line a bit (think about the xy-plane, then this sentence makes more sense). Keep in mind, I don't want any internal faces, boundaries or baffles, I simply want the line inside the mesh and the surrounding cells to adapt to it. Now, I have briefly worked with snappyHexMesh before, however, I only worked with volumes that I cut out of other volumes, resulting in new boundaries and faces and all that. This time, although snappyHexMesh doesn't give me an error, the mesh stays unchanged after execution. Now, before I post any dicts, full cases or terminal outputs, I want to hear your opinion on this approach. Am I am trying to do something that one simply shouldn't do with snappyHex? At first, this seemed like an easy task, but now I'm not so sure anymore. Do I need to use some kind of other feature from OpenFOAM? I read something about surfaceFeatureExtract, createBaffle and topoSet but I couldn't really find any information that sounded useful to my case. I know, I can simply achieve my goal by using gmsh, but I've had really bad experiences with gmsh and OpenFOAM when it comes to the performance of the solver that I'll be using. I think it's also possible to already incorporate these wavy splines in blockMesh, but I don't think blockMesh offers any of the snapping and refining of snappyHex, which is why I want to do this with snappyHex in the first place. Let me know what you think! Best regards Finn |
September 19, 2022, 03:34 |
Yann
Rep Power: 26 |
Hi Finn,
Try something like this: Code:
refinementSurfaces { yourSurface { level (1 1); // whatever refinement you want to apply on the surface faceZone yourName; } } Cheers, Yann |
September 23, 2022, 02:43 |
Rep Power: 4 |
Hey Yann,
thanks for the tip. I've learned a lot over the last couple of days. The level parameter you mentioned in the refinementSurfaces sub-dictionary was definitely one of the things that were important and worked instantly for me. Btw, I read your name in many of the posts, so thanks for helping people To achieve "real snapping" I also had to extract the feature edge and include the resulting eMesh file as feature castellatedMeshControls sub-dictionary. If I didn't do this, the edges were just approximately fitted. This way, the exact shape of my stl was considered. One thing, that didn't do anthing good for me was the nCellsBetweenLevels parameter, which only worked for a value of 2, anything higher than that resulted in the same mesh as for a value of 1. After trying to manipulate it, I eventually just set it to 1 and refined my mesh via the refinementRegions and its mode distance. This also allowed to just set the level parameter in the refinementSurfaces to 0. Furthermore, I had to somehow keep SHM from creating a new boundary from my stl-file since it was just a thin slice that I wanted to consider in the meshing process. I was able to achieve this by not creating regions when defining the geometry in the geometry sub-dictionary. Additionally, I created a faceZone for my geometry in the refinementSurfaces sub-dictionary. Without the declaration of a faceZone, SHM created a boundary and even created some holes at the location of my geometry. Lastly, I had to use the extrudeMesh utility to create a 2D mesh out of my results. I attached my snappyhexMeshDict just in case anyone is interested in this. Feel free to correct me if you noticed that I misunderstood anything. Best regards Finn Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers false; geometry { duneSurface.stl // STL filename { type triSurfaceMesh; name dunes; // User-defined patch name } }; castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 2000000; maxLoadUnbalance 0.1; minRefinementCells 0; nCellsBetweenLevels 1; resolveFeatureAngle 10; features ( { file "duneSurface.eMesh"; level 1; } ); refinementSurfaces { dunes { level (0 0); faceZone dunes; } } refinementRegions { dunes { mode distance; levels ( (0.01 3) // refinement level 3 between 0 mm and 5 mm. (0.05 2) // refinement level 2 between 5 mm and 15 mm. (0.1 1) // refinement level 1 between 5 mm and 50 mm. ); } } locationInMesh (1.701234 0.0101234 0.004); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 3; // nSmoothInternal 3; tolerance 2.0; nSolveIter 100; nRelaxIter 5; nFeatureSnapIter 10; explicitFeatureSnap true; multiRegionFeatureSnap false; implicitFeatureSnap false; } addLayersControls { relativeSizes true; layers { } expansionRatio 1.0; finalLayerThickness 0.3; minThickness 0.25; nGrow 0; featureAngle 60; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-15; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; relaxed { maxNonOrtho 75; } } mergeTolerance 1e-6; |
September 23, 2022, 06:54 |
#4 | |||
Yann
Rep Power: 26 |
Hi Finn,
I am glad I could help! Quote:
In your case, this is either a bug or a problem related to you setup. How many cells do you have in your final mesh? The parameters below limit your mesh to a maximum of 2 millions cells and 1 million cells/core. Code:
maxLocalCells 1000000; maxGlobalCells 2000000; Quote:
If this is not the result your get, then it means there is something going on with your setup. It could also be related to the issue I was mentioning before with maxGlobalCells/maxLocalCells. Everything else sounds good to me: feature edges to get proper snapping, faceZones to snap on a face without creating a patch, using extrudeMesh to get a 2 mesh... All good! Cheers, Yann |
September 23, 2022, 08:53 |
#5 | |||||
Rep Power: 4 |
Hey Yann,
The parameter minRefinementCells did not seem to have any influence whatsoever in my case. It's probably setup related, as I have used nCellsBetweenLevels in a prior example successfully. However, the thread you linked also mentions the workaround I already employed which is mode distance and I'm happy with that. Quote:
duneSurface.stl // STL filename { type triSurfaceMesh; name dunes; // User-defined patch name regions { dunesurfaces { name dunesurfaces; } } } Quote:
Stuff seems to be working right now, thank you Yann Best regards, Finn |
September 23, 2022, 09:47 |
Yann
Rep Power: 26 |
Hi Finn,
Thanks for your feedback, it seems we are all good then! minRefinementCells will have no effect on your refinement levels but it is useful when snappy get stuck trying to refine few cells during refinement iterations. https://www.openfoam.com/documentati...efinementCells Regards, Yann |
[snappyHexMesh] Snappy creates strange cells far away from boundary | vainilreb | OpenFOAM Meshing & Mesh Conversion | 3 | December 16, 2020 05:11 |
