[snappyHexMesh] Snapping issue at cell level change
Like Tree1Likes
  • 1 Post By AtoHM
Prev Previous Post   Next Post Next
Old   March 10, 2023, 09:07
Default Snapping issue at cell level change
DGT
Damien
DGT is on a distinguished road
I am trying to mesh a table and a beam in an external flow (see first picture below).
My table is thin (chord>2m, span~0.7m, thickness=~30mm, : it requires high splitting levels to castellated it properly in the vicinity of the leading edge/trailing edge/tip. But, in order to avoid a to fine mesh on the whole upper and lower side, I defined surfaces and a refinement level associated to these surfaces.
The second picture shows the stl discretization.
Unfortunately, the mesh projection step is ending badly as can be seen on the last picture below.
If you have already encountered this problem or know how to solve it, please tell me.
Thank you
Damien
Here is my blockMeshDict:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   1;
xmin -4.0;
xmax 8.0;
ymin 4.5;
ymax 5.5;
zmin 1.0;
zmax 12.0;
vertices
    ($xmin $ymin $zmin)
    ($xmax $ymin $zmin)
    ($xmax $ymax $zmin)
    ($xmin $ymax $zmin)
    ($xmin $ymin $zmax)
    ($xmax $ymin $zmax)
    ($xmax $ymax $zmax)
    ($xmin $ymax $zmax)
blocks
    hex (0 1 2 3 4 5 6 7) (48 4 44) simpleGrading (1 1 1)
edges
boundary
    Limit_ysplit_outer
        type patch;
        faces
            (1 5 4 0)
    Limit_ymax
        type patch;
        faces
            (3 7 6 2)
    Inlet
        type patch;
        faces
            (0 4 7 3)
    Outlet
        type patch;
        faces
            (2 6 5 1)
    Ground
        type patch;
        faces
            (0 3 2 1)
    Top
        type patch;
        faces
            (4 5 6 7)
and here is the snappyHexMeshDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
geometry
   Beam_outer.stl
        type triSurfaceMesh;
        name Beam_outer;
        regions
            BEAM_WALL        {name BEAM_WALL;}
            BEAM_YSPLIT      {name BEAM_YSPLIT;}
    Table_outer_splitted.stl
         name Table_outer;
         regions
             TABLE_UPPER_L4  {name TABLE_UPPER_L4;}
             TABLE_UPPER_L3     {name TABLE_UPPER_L3;}
             TABLE_UPPER_L2     {name TABLE_UPPER_L2;}
             TABLE_UPPER_L1     {name TABLE_UPPER_L1;}
             TABLE_UPPER_L0     {name TABLE_UPPER_L0;}
             TABLE_LOWER_L4     {name TABLE_LOWER_L4;}
             TABLE_LOWER_L3     {name TABLE_LOWER_L3;}
             TABLE_LOWER_L2     {name TABLE_LOWER_L2;}
             TABLE_LOWER_L1     {name TABLE_LOWER_L1;}
             TABLE_LOWER_L0     {name TABLE_LOWER_L0;}
             TABLE_YSPLIT     {name TABLE_YSPLIT;}
             TABLE_YMAX_TIP     {name TABLE_YMAX_TIP;}
             TABLE_TE         {name TABLE_TE;}
             TABLE_LE         {name TABLE_LE;}
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 20000000;
    minRefinementCells 20;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2;
    features (
                {file "Table_outer.eMesh";                     level 4;}
                {file "Beam_outer.eMesh"; level 4;}
            file "Table_ytip_edges.eMesh";
              levels ((0.01 5));
            file "Beam_corner_edges1.eMesh";
              levels ((0.025 5));
            file "Beam_corner_edges2.eMesh";
            levels ((0.028 5));
            file "Beam_corner_edges3.eMesh";
            levels ((0.025 5));
            file "Beam_corner_edges4.eMesh";
            levels ((0.028 5));
    resolveFeatureAngle 30;
    featureAngle 30;
    locationInMesh (0.1233 5.0846797987 3.33);
    allowFreeStandingZoneFaces true;
    refinementSurfaces
        Beam_outer
            level (4 4);
            regions
        Table_outer
        { //Table1_5deg
            level (2 2);
            regions
                TABLE_UPPER_L4           // Named region in the STL file
                    level (6 6);
                    patchInfo {type wall;}
                TABLE_LOWER_L4        // Named region in the STL file
                    level (6 6);
                TABLE_UPPER_L3           // Named region in the STL file
                    level (5 5);
                TABLE_LOWER_L3        // Named region in the STL file
                    level (5 5);
                TABLE_UPPER_L2           // Named region in the STL file
                    level (3 4);
                TABLE_LOWER_L2        // Named region in the STL file
                    level (3 4);
                TABLE_UPPER_L1           // Named region in the STL file
                    level (2 3);
                TABLE_LOWER_L1        // Named region in the STL file
                    level (2 3);
                TABLE_UPPER_L0           // Named region in the STL file
                    level (2 3);
                TABLE_LOWER_L0        // Named region in the STL file
                    level (2 3);
                TABLE_LE            // Named region in the STL file
                    level (6 6);
                TABLE_TE            // Named region in the STL file
                    level (6 6);
                TABLE_YMAX_TIP            // Named region in the STL file
                    level (6 6);
            }//regions
        }//Table1_5deg
    refinementRegions
snapControls
    nSmoothPatch 10;
    tolerance 30.0;
    nSolveIter 10;
    nRelaxIter 7;
    nFeatureSnapIter 30;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap false;
addLayersControls
    relativeSizes false;
    expansionRatio 1.2;
    firstLayerThickness 0.0005;
    minThickness 0.00005;
    nGrow 0;
    featureAngle 130;
    slipFeatureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedialAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 15;
    layers
        Beam_5deg_mesh
            nSurfaceLayers 12;
            firstLayerThickness 0.001;
        Table1_lower_wall            // Named region in the STL file
            nSurfaceLayers 12;
        Table1_upper_wall            // Named region in the STL file
            nSurfaceLayers 12;
        Table1_te_wall            // Named region in the STL file
            nSurfaceLayers 12;
        Table1_le_wall            // Named region in the STL file
            nSurfaceLayers 12;
        Table1_tip_wall            // Named region in the STL file
            nSurfaceLayers 12;
meshQualityControls
    #include "meshQualityDict"
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 1;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
    maxConcave 30.0;
// Advanced
// Write flags
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
DGT is offline   Reply With Quote
[snappyHexMesh] Celllevel does not satisfy 2:1 constraint zippy OpenFOAM Meshing & Mesh Conversion 0 January 3, 2023 12:47
[snappyHexMesh] SHM Bad quality snapping/terracing ryan55510 OpenFOAM Meshing & Mesh Conversion 0 April 20, 2022 20:20
Parallel computing error using multiple nodes Jingxue Wang OpenFOAM Running, Solving & CFD 11 January 14, 2018 10:51
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 13:30
