[Commercial meshers] Unknown error when converting fluent mesh to openfoam
Old   April 23, 2023, 02:30
Default Unknown error when converting fluent mesh to openfoam
anonymous
Yutao is on a distinguished road
I'm trying to use fluent meshing to deal with my mesh. But I met the following problem when using fluent3DMeshToFoam. The fluent version is Ansys 2023r1 and I'm sure the .msh file is in ascii format. I can't find any similar error information on google.
>>fluent3DMeshToFoam reactor.msh
Create time
Dimension of grid: 3
Number of points: 155034
--> FOAM Warning : Found unknown block of type: "11"
    on line 17
Number of faces: 802867
Number of cells: 329001
PointGroup: 1 start: 0 end: 1073.  Reading points...done.
PointGroup: 5988 start: 1074 end: 1387.  Reading points...done.
PointGroup: 6346 start: 1388 end: 17471.  Reading points...done.
PointGroup: 6459 start: 17472 end: 155033.  Reading points...done.
    on line 155062
    on line 155100
    on line 155138
    on line 155176
    on line 155384
    on line 155592
    on line 155630
    on line 155668
FaceGroup: 6457 start: 33317 end: 802866.  Reading mixed faces...done.
FaceGroup: 1971 start: 0 end: 373.  Reading mixed faces...done.
FaceGroup: 1972 start: 374 end: 727.  Reading mixed faces...done.
FaceGroup: 1973 start: 728 end: 1089.  Reading mixed faces...done.
FaceGroup: 1974 start: 1090 end: 31803.  Reading uniform faces...done.
FaceGroup: 5 start: 31804 end: 31837.  Reading uniform faces...done.
FaceGroup: 4 start: 31838 end: 31871.  Reading uniform faces...done.
FaceGroup: 3 start: 31872 end: 31905.  Reading uniform faces...done.
FaceGroup: 2 start: 31906 end: 33316.  Reading uniform faces...done.
CellGroup: 6451 start: 0 end: 329000 type: 1
--> FOAM Warning : Found unknown block of type: "71"
    on line 958593
    on line 974013
    on line 974279
    on line 974541
Zone: 6451 name: reactor type: fluid.  Reading zone data...done.
Zone: 2 name: reactor:reactor-reactor type: wall.  Reading zone data...done.
Zone: 3 name: inlet1 type: wall.  Reading zone data...done.
Zone: 4 name: inlet2 type: wall.  Reading zone data...done.
Zone: 5 name: outlet type: wall.  Reading zone data...done.
Zone: 1974 name: reactor:reactor-reactor:1974 type: wall.  Reading zone data...done.
Zone: 1973 name: inlet1:1973 type: velocity-inlet.  Reading zone data...done.
Zone: 1972 name: inlet2:1972 type: velocity-inlet.  Reading zone data...done.
Zone: 1971 name: outlet:1971 type: pressure-outlet.  Reading zone data...done.
Zone: 6457 name: interior-6457 type: interior.  Reading zone data...done.
Zone: 1979 name: inlet1:feature:1979 type: boundary-edge.  Reading zone data...done.
Zone: 1978 name: inlet2:feature:1978 type: boundary-edge.  Reading zone data...done.
Zone: 1977 name: outlet:feature:1977 type: boundary-edge.  Reading zone data...done.
Zone: 1976 name: reactor:reactor-reactor:feature:1976 type: boundary-edge.  Reading zone data...done.
Zone: 9 name: reactor:reactor-reactor:feature type: boundary-edge.  Reading zone data...done.
Zone: 8 name: outlet:feature type: boundary-edge.  Reading zone data...done.
Zone: 7 name: inlet2:feature type: boundary-edge.  Reading zone data...done.
Zone: 6 name: inlet1:feature type: boundary-edge.  Reading zone data...done.
--> FOAM Warning : Found unknown block of type: "73"
    on line 975991
FINISHED LEXING
Creating patch 0 for zone: 1971 name: outlet:1971 type: pressure-outlet
Creating patch 1 for zone: 1972 name: inlet2:1972 type: velocity-inlet
Creating patch 2 for zone: 1973 name: inlet1:1973 type: velocity-inlet
Creating patch 3 for zone: 1974 name: reactor:reactor-reactor:1974 type: wall
Creating patch 4 for zone: 5 name: outlet type: wall
Creating patch 5 for zone: 4 name: inlet2 type: wall
Creating patch 6 for zone: 3 name: inlet1 type: wall
Creating patch 7 for zone: 2 name: reactor:reactor-reactor type: wall
Creating cellZone 0 name: reactor type: fluid
Creating faceZone 0 name: interior-6457 type: interior
faceZone from Fluent indices: 33317 to: 802866 type: interior
patch 0 from Fluent indices: 0 to: 373 type: pressure-outlet
patch 1 from Fluent indices: 374 to: 727 type: velocity-inlet
patch 2 from Fluent indices: 728 to: 1089 type: velocity-inlet
patch 3 from Fluent indices: 1090 to: 31803 type: wall
patch 4 from Fluent indices: 31804 to: 31837 type: wall
patch 5 from Fluent indices: 31838 to: 31871 type: wall
patch 6 from Fluent indices: 31872 to: 31905 type: wall
patch 7 from Fluent indices: 31906 to: 33316 type: wall
--> FOAM FATAL ERROR: (openfoam-2206)
Illegal cell label -1 in owner addressing for face 801354
    From void Foam::polyMesh::initMesh()
    in file meshes/polyMesh/polyMeshInitMesh.C at line 64.
FOAM exiting
Someone said that in the msh file after ansys 2021, the section
(0 "Cortex variables:")
(0 "TGrid variables:")
should be deleted. But that doesn't work.
Can somebody help me?
I also tried to save the file as file.cas.gz and file.msh.gz, and gunzip them. but this error also happens. And it can't be opened with paraview too
Yutao is offline   Reply With Quote
fluent3dmeshtofoam
Gmsh reports an OpenCascade exception when opening a .geo file algc Main CFD Forum 2 October 24, 2022 05:59
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[Commercial meshers] converting ICEM mesh to OpenFOAM bmikuz OpenFOAM Meshing & Mesh Conversion 9 May 10, 2016 16:47
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
