October 17, 2017, 09:15 |
rotate searchableBox
Fridrik Magnusson
Rep Power: 8 |
Hallo Everyone
Im trying to rotate a searchableBox 60 deg (pi/3) with the following command: Code:
refinementBox4 { type searchableBox; min (0.355 0.190 -0.01); max (0.485 0.250 0.12); transform { coordinateSystem { type cartesian; origin (0 0 0); coordinateRotation { type localAxesRotation; e3 (60 0 0); } } } } |
August 12, 2018, 07:41 |
#2 | |
KAWA
Rep Power: 8 |
Hi Fridrik, Have you solved this problem, I have exactly the same problem? Regards |
November 9, 2019, 09:56 |
#3 | |
Kristina
Rep Power: 8 |
I rotated searchableBox for 45 deg. around y-axes. Code:
zone1 { name zone1; type searchableRotatedBox; span (1 1 1); //dimensions of the box origin (0 0 -0.707); //first corner of the box - origin of local coordinate system //definition of the axes of the local coordinate system (cartesian, left-handed coordinate system) e1 (0.707 0 0.707); //relationship of e1 local axes and global coord.system e3 (-0.707 0 0.707); //relationship of e3 local axes and global coord.system } |
July 31, 2023, 03:19 |
#4 | |
Rep Power: 2 |
Suppose my box is located with : min(x1, y1, z1), max(x2, y2, z2), and that the origin for the rotation is outside my box. How do I do that? If you have a solution, I would be glad because I could not find anything relevant but your post. |
July 31, 2023, 05:42 |
M
Rep Power: 12 |
Cool - I was not aware this is possible.
However - I would not approach this on the snappy-Level, but build this kind of geometry in a CAD tool where I can convince myself visually that it comes out right, export that to stl and use it as a refinement region. |
August 1, 2023, 04:19 |
Rep Power: 2 |
I guess this is the simplest way and a no-echec solution, but that can take a lot of time if there is 3 internal refined meshes to rotate for 12 different angles. Good solution though. Thanks
rotating, searchablebox, shm |
[Gmsh] Rotate and duplicate mesh! | tareqkh | OpenFOAM Meshing & Mesh Conversion | 1 | December 23, 2019 13:01 |
Rotate frame reference in transient simulation | wjy-c | CFX | 4 | September 4, 2013 21:20 |
How to rotate a pointScalarField? | carowjp | OpenFOAM Programming & Development | 5 | January 27, 2013 19:49 |
surfaceTransformPoints -rotate | ynos | OpenFOAM Post-Processing | 1 | July 11, 2012 15:35 |
[GAMBIT] Rotate and revolute possible ? | Ijaz | ANSYS Meshing & Geometry | 19 | January 26, 2012 23:36 |
