[mesh manipulation] stitchMesh, impossible to stitch two meshes
Old   December 22, 2023, 11:43
Default stitchMesh, impossible to stitch two meshes
redfox1221 is on a distinguished road
Hello everybody,
I have a very large and complex stl object of which I want to make several simulations at different z-angles but doing snappyhexmesh multiple time is very expensive.
I come to the idea to split the mesh in two parts (external and internal) using a cylinder, rotate the internal mesh, merge the meshes and re do the simulation bypassing the snappy hex mesh part.
However after doing the mergeMeshes command the faces are considered walls and i need to use the stitch function to connect them.
Unfortunately i have this error:
stitchMesh -partial -toleranceDict toleranceDict -overwrite cylinder1 cylinder2
--> FOAM FATAL ERROR:
Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(90670 94290 99836 97583) local face 4(1145 144 143 1146)
Slave size: 6400 Master size: 8700 index: 407.
Face: 6(69382 63526 66979 70500 69381 115836)
I also tryed the perfect option as suggested here stitchMesh : duplicate point but it says that it cannot found a points within the matching tolerance
stitchMesh -perfect -toleranceDict toleranceDict -overwrite cylinder1 cylinder2
Points on patch sides do not match to within tolerance 1.11957e-05
I am using the toleranceDict file in the constant folder but it seems that even if I increase the values the error stay the same like it is not using it.
I am using OF10, repo git here Github Repo with a prism to replicate the error, run with ./Allrun.
Any ideas on how to solve?
redfox1221 is offline   Reply With Quote
[PyFoam] Merge and Stitch meshes using pyFoam libraries shaileshbg OpenFOAM Community Contributions 2 March 2, 2018 06:01
Merge and Stitch meshes using pyFoam libraries shaileshbg OpenFOAM Programming & Development 1 February 19, 2018 01:30
[mesh manipulation] stitchMesh: multiple meshes GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 3 August 25, 2017 12:43
[mesh manipulation] Problem with stitchMesh: it does not work in meshes with several common patches arnau1985 OpenFOAM Meshing & Mesh Conversion 2 June 25, 2013 08:49
stitchMesh for uncongruent patches (stitch tolerance) beugold OpenFOAM 0 June 18, 2009 07:38
