[snappyHexMesh] Snapping to baffle or internal face zone |
December 31, 2023, 07:08 |
Tuomo Keskitalo
Rep Power: 15 |
I'm testing Snappy for meshing this helical mixer vessel: Screenshot_2023-12-31_09-00-23.jpg I'm using face zones for the highlighted helix surfaces (no thickness) then adding layers on them. However, my main question is about snapping to helix surface edges: I wonder is it possible to get a smooth snapping on the righmost (see below) curve where block mesh cells are not aligned with the helix edges? I've tried to relax quite a few quality criteria. There is some improvement but there are always some kinks. I suppose this is more of a beauty issue, but still. Here's an example: Screenshot_2023-12-31_09-01-55.jpg BR, Tuomo |
baffle, face zone, snapping |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 12:42 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
