[snappyHexMesh] Snapping to baffle or internal face zone
Old   December 31, 2023, 07:08
Smile Snapping to baffle or internal face zone
Tuomo Keskitalo
tkeskita is on a distinguished road
I'm testing Snappy for meshing this helical mixer vessel:
I'm using face zones for the highlighted helix surfaces (no thickness) then adding layers on them. However, my main question is about snapping to helix surface edges: I wonder is it possible to get a smooth snapping on the righmost (see below) curve where block mesh cells are not aligned with the helix edges? I've tried to relax quite a few quality criteria. There is some improvement but there are always some kinks. I suppose this is more of a beauty issue, but still. Here's an example:
BR,
Tuomo
tkeskita is offline   Reply With Quote
baffle, face zone, snapping
Seakeeping Solver:Crashed akbarbagusd Fidelity CFD 0 November 5, 2021 12:42
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
