[snappyHexMesh] Snapping issues with angled cylinder
Old   January 5, 2024, 13:51
Default Snapping issues with angled cylinder
Justin Weber
onlyjus is on a distinguished road
I have an 30 degree angled cylinder in-between two plates that I am having issue with snapping to the STL file. The STL file has a nice triangular surface generated with gmsh.
At the lower resolution mesh (larger cells) I get ok snapping.
But if I refine the mesh, some cells snap well, but the majority of them don't seem to snap at all.
Here are my snapping parameters. Any ideas?
snapControls
    nSmoothPatch 1;
    //nSmoothInternal $nSmoothPatch;
    tolerance 1.0;
    nSolveIter 500;
    nRelaxIter 100;
    nFeatureSnapIter 30;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap false;
onlyjus is offline   Reply With Quote
Old   January 6, 2024, 00:23
Justin Weber
I figured it out. I was running into the minVol limit in the meshQualityDict.cfg. Lowering this to
minVol 1e-18;
did the trick
snap controls, snappyhexmesh
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
How to implement time-varying boundary conditions in an enclosed cylinder Alejandro-FA OpenFOAM Pre-Processing 0 May 14, 2020 06:29
[ICEM] Delete angled cylinder inside a block harman79 ANSYS Meshing & Geometry 11 September 26, 2012 05:54
3D cylinder and Vortex Street shedding issues josik_1982 FLUENT 2 July 17, 2010 10:19
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
