[snappyHexMesh] blockmesh edge problem with snappyhexmesh |
February 4, 2024, 18:40 |
önay bilgen
Rep Power: 2 |
I want to do a propeller analysis using the srfsimplefoam solver. As seen in the pictures below, I get an error when I place the propeller where I want. But when I move the propeller to the middle, I don't get any errors. I made the flow field with blockmesh. Thank you in advance for your help
February 4, 2024, 18:51 |
Burhan Göktürk
I am also facing the same problem. But I don't know the solution .
[snappyHexMesh] Problem with skewd faces in SnappyHexMesh | Friendly | OpenFOAM Meshing & Mesh Conversion | 1 | June 19, 2019 07:05 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Problem in results with snappyHexMesh between refinement levels | Phil_WO | OpenFOAM Meshing & Mesh Conversion | 2 | November 8, 2018 03:49 |
[snappyHexMesh] problem with snappyHexMesh | kanes | OpenFOAM Meshing & Mesh Conversion | 10 | January 26, 2016 06:11 |
[snappyHexMesh] Problem with snappyHexMesh | samiam1000 | OpenFOAM Meshing & Mesh Conversion | 2 | December 13, 2012 08:41 |
