[mesh manipulation] 2D Axisymmetric Mesh Not Working for Custom STL Multiphase Geometry
Prev Previous Post   Next Post Next
Old   March 12, 2024, 10:16
Default 2D Axisymmetric Mesh Not Working for Custom STL Multiphase Geometry
Muhd Jamil Al Hakim
Jamill1283 is on a distinguished road
Send a message via Yahoo to Jamill1283 Send a message via Skype™ to Jamill1283
Dear Foamers,
I'm facing an issue with a multiphase flow simulation that involves modeling a liquid ligament in air. The geometry of the ligament, which is custom-designed using CAD software, has been exported to an STL file for this purpose.
My objective is to simulate this specific geometry in a 2D axisymmetric manner. However, I'm encountering a problem when the simulation is set up with a 2D mesh (having a mesh count of 1 in the z-direction); the liquid phase, which has a volume fraction of 1, does not appear correctly in the simulation. Interestingly, when I increase the mesh count in the z-direction to a higher number, the liquid's shape is accurately represented.
My blockmesh is as below;
scale 0.001;
blockWidth #eval "3";
ligamentSize #eval "0.5";
theta #eval "45.0 / 8";
arcLocZ #eval "($blockWidth) * sin(degToRad($theta))";
arcLocY #eval "($blockWidth) * cos(degToRad($theta))";
nArcLocZ #eval "-1*$arcLocZ";
ligArcLocZ #eval "($ligamentSize) * sin(degToRad($theta))";
ligArcLocY #eval "($ligamentSize) * cos(degToRad($theta))";
smallArcLocZ #eval "($blockWidth) * sin(degToRad($theta/2))";
smallArcLocY #eval "($blockWidth) * cos(degToRad($theta/2))";
smallLigArcLocZ #eval "($ligamentSize) * sin(degToRad($theta/2))";
smallLigArcLocY #eval "($ligamentSize) * cos(degToRad($theta/2))";
vertices
    (0  0 0)
    (10 0 0)
    (10 $blockWidth 0)
    (0  $blockWidth 0)
    (0 $arcLocY $arcLocZ)
    (10 $arcLocY $arcLocZ)
blocks
    hex (0 3 4 0 1 2 5 1) (100 100 1) simpleGrading (1 1 1) //the issue is here
edges
patches
    patch outlet
        (2 5 1 1)
boundary
    front
        type wedge;
        faces
            (0 1 5 4)
            (0 1 2 3)
    ligament
        type symmetry;
        faces
            (3 4 0 0)
    external
        type wall;
        faces
            (3 4 5 2)
    axis
        type  empty;
        faces
            (0 1 1 0)
mergePatchPairs
Setfields as below;
defaultFieldValues
    volScalarFieldValue alpha.phase1 0
    volVectorFieldValue U (0 0 0)
regions (
   surfaceToCell {
   file           "./constant/fluidStruct/ligament108.stl";
   outsidePoints  ((0.008 0.00025 0));
   includeInside  true;
   includeOutside false;
   includeCut     true;
   nearDistance   -1;
   curvature      -100;
   fieldValues (
   volScalarFieldValue alpha.phase1 1
I'm seeking advice or solutions to ensure that the liquid phase is properly visualized while maintaining the simulation in a strictly 2D axisymmetric setup. Any insights or suggestions would be greatly appreciated.
Attached are visuals for 3D, problem for 2D mesh and zipped STL files;
ligament.zip
Thank you in advance for your assistance.
Jamil
Jamill1283 is offline   Reply With Quote
axisymmetric wedge, mesh, multiphase
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ANSYS Meshing] Help with Mesh/Geomety of 2-D Axisymmetric Geometry yetlyg ANSYS Meshing & Geometry 1 July 1, 2015 02:01
[ICEM] Working on imported STL mesh file saitej09 ANSYS Meshing & Geometry 0 January 16, 2015 06:11
[ANSYS Meshing] Meshing Strategy for inside geometry powpow ANSYS Meshing & Geometry 6 January 16, 2013 04:32
