March 12, 2024, 13:49 |
SnappyHexMesh add layers
Hongbin Wang
Rep Power: 6 |
I am modelling an urban area with buildings on non-flat terrain. I want to add layers to the surface of buildings and terrains. Below the log file of running snappyHexMesh. I don’t understand what it means for “layers”, “overall [m]” and “thickness [%]”. Can someone please help?
patch faces layers overall thickness [m] [%] ----- ----- ------ --- --- buildingSurroundings 9147 2.14 0.138 68.9 innerTerrain 583214 0.00712 0.00303 0.163 Below an excerpt of snappyHexMeshDict for adding layers. addLayersControls { minMedialAxisAngle 90; relativeSizes true; layers { buildingSurroundings { nSurfaceLayers 3; relativeSizes true; minThickness 0.1; finalLayerThickness 0.6; expansionRatio 1.1; } innerTerrain { nSurfaceLayers 4; relativeSizes false; minThickness 0.2; firstLayerThickness 0.4; expansionRatio 1.1; } } expansionRatio 1.2; firstLayerThickness 1; minThickness 0.3; nGrow 0; featureAngle 130; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } |
March 12, 2024, 15:14 |
Lucky
Rep Power: 66 |
there is something wrong with your log output, maybe a copy and past error
patch faces layers overall thickness [m] [%] ----- ----- ------ --- --- buildingSurroundings 9147 2.14 0.138 68.9 innerTerrain 583214 0.00712 0.00303 0.163 buildingSurroundings is the patch 9147 is the number of faces. 3 numbers should follow. A number of layers, an overall thickness of the layers in [m] and an overall thickness of the layers in % in the next line innerTerrain is the patch, it has 583214 faces, 0.00712 layers apparently The last percentage is the percentage of the patch that has been layered. 100% means every face on the patch has a layer. |
March 13, 2024, 08:48 |
Hongbin Wang
Rep Power: 6 |
Hi LuckyTran,
Thanks very much for your response. I attached the log.snappyHexMesh and snappyHexMesh. I don't think I made copy paste error for the log file. Thanks. |
March 13, 2024, 14:14 |
Lucky
Rep Power: 66 |
It doesn't really matter whether you did or not, your question is answered
March 13, 2024, 17:26 |
Hongbin Wang
Rep Power: 6 |
I'm not grasping it yet. The surface of buildingSurroundings has a Layers value of 2.14. However, in sappyHexMesh, 3 layers are specified. What is the “overall”, is it the total height of the 3 layers 0.138m? It doesn’t seem to make sense. Additionally, the term "thickness (%)" seems misleading since it refers to the percentage of all faces being layered, which doesn't seem to align with its name.
Patch faces layers overall([m]) thickness(%) ----- ----- ------ --- --- buildingSurroundings 9147 2.14 0.138 68.9 innerTerrain 583214 0.00712 0.00303 0.163 Last edited by Origami; March 13, 2024 at 17:41. Reason: formating |
March 14, 2024, 08:57 |
Lucky
Rep Power: 66 |
it's actually overall thickness [m] and just a plain unlabeled %
You are arguing pedantics. If you don't agree with it, then simply change it. OpenFOAM is meant to be modifiable, that's why they give you the source code. It's also just a report. You can just open the mesh and look at it and verify with your own eyeballs what the mesh looks like. Take a picture, screenshot it, whatever. |
March 14, 2024, 11:01 |
Hongbin Wang
Rep Power: 6 |
Ok. Thanks for the tip. I'll look at the source code and see if I can crack the code of understanding.
[snappyHexMesh] SnappyHexMesh add Layer Only failed | fxzf | OpenFOAM Meshing & Mesh Conversion | 1 | January 11, 2023 05:14 |
[snappyHexMesh] Add layers at the bottom of a mesh | chayoun | OpenFOAM Meshing & Mesh Conversion | 5 | June 2, 2021 12:35 |
[snappyHexMesh] Inconsistent Layers SnappyHexMesh | CfdUser5855 | OpenFOAM Meshing & Mesh Conversion | 0 | March 10, 2021 14:42 |
[snappyHexMesh] Snappy add layers failed | mqsim | OpenFOAM Meshing & Mesh Conversion | 1 | January 24, 2021 16:02 |
[snappyHexMesh] snappyHexMesh fails adding layers | biscarri | OpenFOAM Meshing & Mesh Conversion | 13 | March 21, 2020 13:40 |
