April 9, 2024, 15:45 |
Adding an Internal Wall
Christoph Trier
Rep Power: 2 |
Hey,
I am new to OpenFOAM and I would like to create an internal wall. I have already finished the blockMeshDict and wanted to add a wall between two blocks, but apparently this is not possible (marked it in red in the code). So, I searched around and came across createBafflesDict and this great video. https://www.youtube.com/watch?v=7Ex1RHDQqIc&t=1s But I need to name the face to create a baffle to create my internal wall. At this point, I thought I would just ask here in parallel to my further search because all I want is to create an internal wall between two blocks to create a boundary condition. An image is attached. Hopefully, one of you can help me further. Best regards, Christoph Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 0.001; vertices ( (0 0 0) (566.5 0 0) (851 0 0) (1133 0 0) (0 214 0) (566.5 214 0) (851 214 0) (1133 214 0) (0 369.6 0) (566.5 369.6 0) (851 369.6 0) (1133 369.6 0) (566.5 1850.5 0) (851 1850.5 0) (1133 1850.5 0) (566.5 2135 0) (851 2135 0) (1133 2135 0) (0 0 161.6) (566.5 0 161.6) (851 0 161.6) (1133 0 161.6) (0 214 161.6) (566.5 214 161.6) (851 214 161.6) (1133 214 161.6) (0 369.6 161.6) (566.5 369.6 161.6) (851 369.6 161.6) (1133 369.6 161.6) (566.5 1850.5 161.6) (851 1850.5 161.6) (1133 1850.5 161.6) (566.5 2135 161.6) (851 2135 161.6) (1133 2135 161.6) ); blocks ( hex (0 1 5 4 18 19 23 22) (30 20 20) simpleGrading (1 1 1) hex (1 2 6 5 19 20 24 23) (20 20 20) simpleGrading (1 1 1) hex (2 3 7 6 20 21 25 24) (20 20 20) simpleGrading (1 1 1) hex (4 5 9 8 22 23 27 26) (30 15 20) simpleGrading (1 1 1) hex (5 6 10 9 23 24 28 27) (20 15 20) simpleGrading (1 1 1) hex (6 7 11 10 24 25 29 28) (20 15 20) simpleGrading (1 1 1) hex (9 10 13 12 27 28 31 30) (20 60 20) simpleGrading (1 1 1) hex (10 11 14 13 28 29 32 31) (20 60 20) simpleGrading (1 1 1) hex (12 13 16 15 30 31 34 33) (20 20 20) simpleGrading (1 1 1) hex (13 14 17 16 31 32 35 34) (20 20 20) simpleGrading (1 1 1) ); boundary ( inlet { type patch; faces ( (0 18 22 4) ); } outlet { type patch; faces ( (4 22 26 8) ); } //internalwall //{ // type wall; // faces // ( // (4 22 23 5) // (5 23 24 6) // (6 24 28 10) // (10 28 31 13) // ); //} wall_out { type wall; faces ( (0 1 19 18) (1 2 20 19) (2 3 21 20) (3 7 25 21) (7 11 29 25) (11 14 32 29) (14 17 35 32) (17 16 34 35) (16 15 33 34) (12 30 33 15) (9 27 30 12) (8 26 27 9) ); } Wall_side { type wall; faces ( (18 19 23 22) (19 20 24 23) (20 21 25 24) (22 23 26 27) (23 24 28 27) (24 25 29 28) (27 28 31 30) (28 29 32 31) (30 31 34 33) (31 32 35 34) (1 0 4 5) (2 1 5 6) (3 2 6 7) (4 8 9 5) (5 9 10 6) (6 10 11 7) (9 12 13 10) (10 13 14 11) (12 15 16 13) (13 16 17 14) ); } ); // ************************************************************************* // |
April 10, 2024, 03:35 |
Rep Power: 5 |
Hey!
If you have created faces at the location of the internal mesh, you can use topoSet to create a new faceZone that includes these faces. Once the faceZone has been created, the utility createBaffles will duplicate the faces to create two patches (usually called master and slave, similar to a wall and its shadow wall in Fluent). You should end up with two patches overlapping but with normals pointing the opposite way. Use whatever boundary condition you need then. Watch out if you use the option -overwrite when using createBaffles if you intend to keep the original mesh. |
April 10, 2024, 04:10 |
Gerhard Holzinger
Rep Power: 28 |
blockMesh itself does not support internal walls. Do your self a favour, and do not try to achieve something with internal walls, what you can achieve with ordinary walls.
I have overlaid your image of the geometry with a block-structure, that consists of connected and unconnected blocks. If you modify your blockMeshDict accordingly, you turn your internal wall into an ordinary wall, which blockMesh is perfectly happy to provide you with. |
April 10, 2024, 10:52 |
Christoph Trier
Rep Power: 2 |
Hey,
Really thanks to Gerhard. Didn't think about it that way. This makes it much easier and I don't have to deal with creatbaffle and the rest. (for now) Best regards, Christoph |
April 10, 2024, 11:02 |
Gerhard Holzinger
Rep Power: 28 |
If the geometry allows for blocking, i.e., creating a representation or a good enough approximation of your geometry, then you can do great things with blockmesh.
Attached is a cut-away of a branching pipeline, all done using blockmesh and extrudemesh with a helping of stitchmesh. The forks and bends are blockmesh-creations, and the straight parts are simply extrusions. There was also a bit of subset-ing and mirror-ing involved. ... anyways, blockmesh can do good things for you. |
internal wall |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[ICEM] Merge meshes with internal wall | BrolY | ANSYS Meshing & Geometry | 20 | February 20, 2013 10:43 |
BC for a permeable internal wall | Andi-HH | OpenFOAM Pre-Processing | 6 | April 24, 2012 10:39 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
