[snappyHexMesh] Issues with Internal Solid Region and Patch Preservation in SHM in multiRegion mesh |
May 13, 2024, 17:18 |
Ali
Rep Power: 2 |
Hello everyone,
I've been working with snappyHexMesh on a geometry that includes two regions: a solid region entirely within a fluid domain. I defined multiple patches for my geometry. The snappyHexMesh process retains the exterior patches, but after it finishes, I can't find the patches of the solid region which are supposed to be within the fluid. Instead, when I execute splitMeshRegions -cellZones, a new patch named "heater_to_room" is created that combines all the solid region's patches. I tried to use the function surfaceToPatch but the patches are created just in the 0.001 file, and they are empty (nFaces 0 in the boundary file). Can someone explain why the internal solid patches are not preserved as separate entities and how I might retain these internal solid patches within the fluid domain in the meshing process? Any tips or suggestions would be greatly appreciated! Thank you in advance! Best Regards! |
May 13, 2024, 17:24 |
Will Kernkamp
Rep Power: 13 |
There is not enough information here. You should look in your Dict files for the name heater_to_room.
May 13, 2024, 17:48 |
Ali
Rep Power: 2 |
Hello Will,
Thank you for your reply. In my setup, the patch named "heater_to_room" is configured as follows in the mesh file: heater_to_room { type mappedWall; inGroups 1(wall); nFaces 48002; startFace 814235; sampleMode nearestPatchFace; sampleRegion room; samplePatch room_to_heater; } My problem is that this patch combines all the faces, but in my original STL file and in my snappyHexMeshDict, I had separated the faces to apply different boundary conditions. How can I keep the original patch divisions? PS: This is how I defined my patches in SHMDict model.stl { type triSurfaceMesh; regions { ceiling { name ceiling; } floor { name floor; } glass_doors { name glass_doors; } insulated_walls { name insulated_walls; } roof { name roof; } back { name back; } down { name down; } front { name front; } left { name left; } right { name right; } upper { name upper; } } } and this are the patches in the output mesh file: ceiling { type wall; inGroups 1(wall); nFaces 2668; startFace 1578061; } floor { type wall; inGroups 1(wall); nFaces 5725; startFace 1580729; } glass_doors { type wall; inGroups 1(wall); nFaces 828; startFace 1586454; } insulated_walls { type wall; inGroups 1(wall); nFaces 26985; startFace 1587282; } roof { type wall; inGroups 1(wall); nFaces 1768; startFace 1614267; } room_to_heater { type mappedWall; inGroups 1(wall); nFaces 48002; startFace 1616035; sampleMode nearestPatchFace; sampleRegion heater; samplePatch heater_to_room; } Hopping it's clearer right now |
May 14, 2024, 04:14 |
#4 | |
Yann
Rep Power: 26 |
Hello Ali,
splitMeshRegions automatically creates interface patches when splitting the mesh. So I think if you want to avoid it you should look into splitMeshRegions options. The option -useFaceZones looks like it could be helpful: Quote:
May 15, 2024, 16:13 |
Ali
Rep Power: 2 |
Hello Yann,
Thank you for you response, I tried running splitMeshRegions -cellZones -useFaces but it only duplicates the name, resulting in something like solid_to_fluid_solid_to_fluid instead of just solid_to_fluid. When I run splitMeshRegions -useFaces, it doesn't detect any regions. Any advice on how to fix this? Thanks! |
May 16, 2024, 03:02 |
Yann
Rep Power: 26 |
It's very hypothetical since I never tried it myself, but I guess you need to define faceZones in snappy beforehand.
Could you post your snappyHexMeshDict? |
May 30, 2024, 15:59 |
Ali
Rep Power: 2 |
Hello Yann,
Thank you for your response, and sorry for the late reply. Here is my snappyHexMeshDict file. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { room.stl { type triSurfaceMesh; regions { ceiling { name ceiling; } floor { name floor; } glass_doors { name glass_doors; } insulated_walls { name insulated_walls; } roof { name roof; } } } heater.stl { type triSurfaceMesh; regions { back { name back; } down { name down; } front { name front; } left { name left; } right { name right; } upper { name upper; } } } hot.stl { type triSurfaceMesh; regions { a { name a; } b { name b; } c { name c; } d { name d; } e { name e; } f { name f; } } } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 1000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 20000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 6; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { room.stl { level (0 0); regions { ceiling { level (0 0); patchInfo { type wall; }} floor { level (0 0); patchInfo { type wall; }} glass_doors { level (0 0); patchInfo { type wall; }} insulated_walls { level (0 0); patchInfo { type wall; }} roof { level (0 0); patchInfo { type wall; }} } } heater.stl { level (0 0); regions { back { level (3 3); patchInfo { type patch; }} down { level (3 3); patchInfo { type patch; }} front { level (3 3); patchInfo { type patch; }} left { level (3 3); patchInfo { type patch; }} right { level (3 3); patchInfo { type patch; }} upper { level (3 3); patchInfo { type patch; }} } } hot.stl { level (0 0); regions { a { level (3 3); patchInfo { type patch; }} b { level (3 3); patchInfo { type patch; }} c { level (3 3); patchInfo { type patch; }} d { level (3 3); patchInfo { type patch; }} e { level (3 3); patchInfo { type patch; }} f { level (3 3); patchInfo { type patch; }} } } } // Resolve sharp angles resolveFeatureAngle 30; locationsInMesh ( (( 0.5647 0.12536 0.376) heater) (( 1.4253 1.25635 1.243) room) (( 0.5647 0.07645 0.113) hot) ); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 1.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Of limited use in this case since faceZone faces not handled. nFeatureSnapIter 10; implicitFeatureSnap true; multiRegionFeatureSnap true; } |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
