[snappyHexMesh] Snappyhexmesh refinement parameters
Old   December 15, 2008, 01:25
Default Snappyhexmesh refinement parameters
liu yang
liuyang is on a distinguished road
Hello all:
I used snappyhexmesh for grid generating and it's quite efficient,but I still don't understand the parameters in subdictionary refinementRegions, the tuturial gives
refinementRegions
refinementBox
mode inside;
levels ((1E15 4));
and I used in a same way, only chages the mode to mode distance. It seems to work too.
My question is , what do the two parameters behind "levels" mean? and is the meanning the same for both inside mode and distance mode?
Thanks in advance.
liuyang is offline   Reply With Quote
Old   December 15, 2008, 03:24
Default Hi Liu, In my point of view (
Velan
velan is on a distinguished road
Hi Liu,
In my point of view (Please reply if it is wrong), mode inside or outside defined from "searchableBox"
So if your mode is inside, inside the searchable region, mesh will be refine and if your mode is outside, mesh will refine outside the searchable area. Here it doesnt matter about where the surface is. Mode distance refine from starting of the surface upto the distance mention.
And levels define how many times each cell has to refine.
Hope this clear your doubt
velan is offline   Reply With Quote
Old   December 15, 2008, 04:09
Default Hi Velan: Thank you very much
liu yang
Hi Velan:
Thank you very much for your reply.
Maybe I didn't make my problem clear. I knew mode distance refine from starting of the surface, and in my case the refinementRegions is specified to the surface of the solid body.
My doubt is, what the two parameters (1E15 4) after "lelvels" means? Can they make my grid generation too slow? 1E15 is quite a large number. I changed it to 10, but the grid is not fine enough.
Thank you and everyone helped.
Old   December 15, 2008, 05:22
Default Hi Liu, mode distance ; le
Velan
Hi Liu,
mode distance ;
levels (A B)
Here A is the distance from the solid surface. The grid will get refine upto the Distance A.
B is the number of refinement level per cell.
For you problem, keep your A constant and increase your B value. You will get more fine grid near the solid surface.
Hope your grid generation will be bit slow. Because it has to split the cells into B level times.
Some other people might explain you more clearly.
Old   December 15, 2008, 07:26
liu yang
Hi Velan:
Thank you very much for your kind help and your patience. Now I'm quite clear.
Liuyang
Old   January 19, 2009, 07:44
Default Hello, Using snappyHexMesh
Bastien Holbek
bholbek is on a distinguished road
Using snappyHexMesh mesh utility, i have successfully created a mesh and my simulation runs fine. I would like to modify it and play a little bit with the different parameters of snappyHexMeshDict file.
Modifying refinement parameters from some given regions or the global level (1E15 4) to (1E15 2) for example, i receive the following error when running my simulation:
Reading environmentalProperties
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
#0 Foam::error::printStack(Foam:stream&) in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so"
#4 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::hThermo(Foam::fvMesh const&) in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so"
#5 Foam::basicThermo::addfvMeshConstructorToTable<foa m::hthermo<foam::puremixture<f oam::consttransport<foam::speciethermo<foam::hcons tthermo<foam::perfectgas> > > > > >::New(Foam::fvMesh const&) in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so"
#6 Foam::basicThermo::New(Foam::fvMesh const&) in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so"
#7 main in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantFoa m"
#8 __libc_start_main in "/lib64/tls/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantFoa m"
checkMesh gives me: Mesh OK. I use the function mapFields to obtain my initial fields, interpolating the fields of an other simulation.
What kind of error is it? Could someone give me a tip?
Thanks
Bastien
bholbek is offline   Reply With Quote
Old   January 19, 2009, 07:46
Bastien Holbek
Thanks
Bastien
Old   January 19, 2009, 09:54
Default Hi Bastien! That does not l
Assistant Moderator
Bernhard Gschaider
Hi Bastien!
That does not look like a problem of snappy to me. The problem happens during the initialization of the thermophysical solver. It would have been nice if you had provided us with the information which solver you are using, but from the type of the error it must be a compressible one. One very popular mistake with those is that p=0 somewhere (either internal or boundary). When OF tries to calculate rho (using the perfect gas relation) it dies with a division by zero.
Have a look at your intial conditions (either with a text editor or paraFoam)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 20, 2009, 05:24
Default Hi, Thank you for your answ
Bastien Holbek
Thank you for your answer. Actually, what makes me think that it could be a problem with snappyHexMesh is that i have run successfully the same simulation on an other mesh.
I just create a new mesh, it means, i replace the polymesh directory and i run exactly the same simulation. I have also to say that i use the mapFields utility with the "-consistent" option, to interpolate the results of a "buoyantSimpleFoam" run. Maybe is there something wrong?
I'm using buoyantFoam solver. It's a transient simulation. I'm trying to modify the mesh because i have high courant numbers, only around my inlet. My mean courant number is really lower. Actually, i impose a quite high velocity on an inlet, which corresponds to one of my stl files for snappyHexMesh. SnappyHexMesh creates quite small cells around this inlet and then i have to use really small time steps so that my courant number is not too high and that my simulation runs fine.
Thus, i'm now trying to play with global or local refinement parameters to avoid small cells near my inlet. But maybe, is it not the good way to resolve my problem?
Any suggestions for these two problems?
Thank you
Bastien
Old   January 23, 2009, 03:48
Default HI, i'm still searching sol
Bastien Holbek
HI,
i'm still searching solutions for my two problems (Post 20 January).
For the first one, i ahve found that the following error appears when i launch a simulation that i have initialized from a solution obtained on a different grid. If i initialize it with a simulation run on the same grid, i do not receive this error. For initialisations, i use the mapField utility with the option concistent.
Create time
Create mesh for time = 400
Gleitkomma-Ausnahme
Any ideas?
Thank you
Bastien
Old   February 5, 2009, 04:25
Default Hi, we are trying to simula
  #11
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
we are trying to simulate a NACA foil 0012. We have just used blockMesh utility to generate a mesh and the simulatation run fine. Now we are trying to test the snappyHexMesh potentiality to study the same case but we are struggling to obtain a good quality mesh around the profile and this trouble has the drawback to substime the cd coefficient. We report next an image about the pressure field around naca's profile and an archive that contains the snappyHexMeshDict, blockMeshDict and naca.stl files we are using.
snappyHexMeshDict
Is there someone that has any good idea about what we can do to improve our solution?
Thank you in advance
Best Regards
Norman
norman1981 is offline   Reply With Quote
Old   February 5, 2009, 04:31
Default Sorry the archive was too huge
  #12
norman1981's Avatar
Norman Del Puppo
Sorry the archive was too huge to be uploaded,
here are the blockMeshDict
and the naca.stl file
Thanks
Norman
[snappyHexMesh] SnappyHexMesh Problem 96faizizzuddin OpenFOAM Meshing & Mesh Conversion 10 October 10, 2022 06:45
[snappyHexMesh] snappyHexMesh Parallel bad size error andrewpomeroy OpenFOAM Meshing & Mesh Conversion 2 April 2, 2018 01:08
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 08:06
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) Irish09 OpenFOAM Meshing & Mesh Conversion 23 July 15, 2013 07:45
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
