[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase |
April 28, 2008, 18:34 |
Simone.Sa
Hi all!
When I try to use collapseEdges after makeAxialMesh in the testcase of the subversion MakeAxialMesh utility I receive the same error at all times, with different value of merge angle and edge lenght: Morphing ... --> FOAM Warning : From function boundBox::boundBox(const pointField& points) in file meshes/boundBox/boundBox.C at line 52 cannot find bounding box for zero sized pointFieldreturning zero --> FOAM Warning : From function boundBox::boundBox(const pointField& points) in file meshes/boundBox/boundBox.C at line 52 cannot find bounding box for zero sized pointFieldreturning zero Collapsing 0 small edges Collapsing 0 in line edges #0 Foam::error::printStack(Foam:stream&) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7f1e420] #3 collapseHighAspectFaces(Foam::polyMesh const&, Foam::PackedList<1> const&, double, double, Foam::edgeCollapser&) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges" #4 main in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 __gxx_personality_v0 in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges" Segmentation fault What's wrong? Can someone help me to find the right value of edge lenght and merge angle for this testCase? Thanks Simone |
June 5, 2009, 03:24 |
Problems with collapseEdges
Hello to all,
has anybody found a solution for this problem? Unfortunately I have the same problem and request your help. thx, mike |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Error will loading makeAxialMesh utility in openFOAM-1.6 | will_avoid_comm_solvers | OpenFOAM | 21 | October 21, 2014 05:16 |
collapseEdges (after makeAxialMesh) not worked | mechy | OpenFOAM | 2 | November 17, 2011 15:09 |
makeAxialMesh > collapseEdges!! | billynoe | OpenFOAM | 17 | February 21, 2011 04:29 |
Modification of collapseEdges utility | olwi | OpenFOAM Bugs | 0 | September 9, 2008 08:35 |
