[Gmsh] Error using gmshToFoam
Old   April 25, 2007, 06:26
Default Error using gmshToFoam
Giuseppe Noviello
derath is on a distinguished road
Hi to all,
I'm using the utility gmshToFoam for importing a my mesh in foam but I've this:
Exec : gmshToFoam /home/giuseppe/OpenFOAM/giuseppe-1.4/run/tutorials/turbFoam serra modello.msh
Date : Apr 25 2007
Time : 12:29:14
Host : linux-cplb
PID : 21203
Root : /home/giuseppe/OpenFOAM/giuseppe-1.4/run/tutorials/turbFoam
Case : serra
Nprocs : 1
Create time
#0 Foam::error::printStack
#1 Foam::sigSegv::sigSegvHandler
#2 Uninterpreted: [0xb7fa1420]
#3 main
#4 __libc_start_main
#5 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
Segmentation fault
Someone can help me?
thanks in advantage
derath is offline   Reply With Quote
Old   April 25, 2007, 07:05
Default Hi again, This time I'm not s
Takuya OSHIMA
7islands is on a distinguished road
Hi again,
This time I'm not so sure but if you are running gmshToFoam from FoamX the safest way to specify the .msh file is to use the full path, for example
/home/giuseppe/OpenFOAM/giuseppe-1.4/run/tutorials/turbFoam/serra/modello.msh
(or something like that).
If you're running from the command line check if the modello.msh file is surely in the current directory.
Takuya
7islands is offline   Reply With Quote
Old   April 25, 2007, 15:51
Default Hi, Maybe you should post t
Billy
billy is on a distinguished road
Maybe you should post the msh file.
billy is offline   Reply With Quote
Old   May 2, 2016, 08:37
Martin Silkens
ms411 is on a distinguished road
I had the same problem, you have to copy and save all relevant folders of the constant folder. After it you have to remove the constant folder. The *.msh file should be in the same folder like 0 and system folder. Then you can execute gmshToFoam command. Then a new constant folder blows up and you have to paste all relevant files into the new constant folder.
Done!
Best,
Martin
ms411 is offline   Reply With Quote
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 10:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 03:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 07:36
