[Commercial meshers] Problem with Mesh conversion Gambit msh Foam
Old   February 22, 2005, 11:17
Default Problem with Mesh conversion Gambit msh Foam
Rachid BANNARI (Bannari)
I have a problem to convert .msh file (obtained by
Gambit) to foam file. In fact the execution of the command
fluentMeshToFoam I obtained that the mesh created. when I chek, the file
blockMeshDict doasn't exist. with an other .msh file I did not have
this problem, but a FOAMFATAL ERROR... (problem in
Istream.C file). I hope know if somone
success this conversion, and how can I do that?
thanks
Old   February 22, 2005, 11:39
Default You will not get a blockMeshD
Mattijs Janssens (Mattijs)
You will not get a blockMeshDict. A blockMeshDict is the input file for OpenFOAM's own block mesher.
The fluentMeshToFoam will have written the polyMesh files (points, faces, cells).
Mattijs
Old   February 22, 2005, 13:13
Default indeed the changes had place i
BANNARI (Bannari)
indeed the changes had place in points, faces, cells but with the command I have
--> FOAM FATAL ERROR : Cannot find mesh description file
"constant/polyMesh/blockMeshDict" or
"constant/polyMesh/meshDescription" or
"constant/mesh/meshDescription"
thank you
Old   February 22, 2005, 13:18
Default With what command?
Henry Weller (Henry)
With what command?
Old   February 22, 2005, 13:37
Default Hi, Sorry if this sounds s
Niklas Nordin (Niklas)
Sorry if this sounds stupid, but why are
you running the fluent converter on what I
understand is a gambit mesh?
How about using gambitToFoam instead?
N
Old   February 22, 2005, 13:39
Default Easy Tiger, Fluent files w
Hrvoje Jasak (Hjasak)
Easy Tiger,
Fluent files will have the .msh and .cas extensions and you convert them with fluentMeshToFoam. Gambit files have the .neu extension and you use the gambitToFoam converter.
Hrv
Old   February 22, 2005, 14:14
Default I have some results in Fluen
BANNARI (Bannari)
I have some results in Fluent. and I want to run the same problem in Foam to compare. To do that I want to transform my mesh file from fluent to Foam but unfortunately I do not succeeded that, even I follow the instructions in Foam manual
I convert this file (.msh) with:
>fluentMeshToFoamroot casename file.msh
after that
>blochMesh ...
in the points, faces, cells files I have the informations but I can't view the mesh in paraview
P.S. I'm new user of Foam
Old   February 22, 2005, 14:50
Default >after that >>blochMesh ...
>after that
>>blochMesh ...
Why are you running blockMesh after fluentMeshToFoam? It makes no sense; blockMesh generates a mesh from a blockMeshDict mesh description file and has absolutely nothing to do with the mesh converters.
Old   February 22, 2005, 14:56
Default ok so how can I visualise m
BANNARI (Bannari)
ok
so how can I visualise my converted mesh
thank you
Old   February 22, 2005, 15:02
Default Use paraFoam
Use paraFoam
Old   March 12, 2005, 01:54
Default Here is my issue with a mesh o
  #11
tchavdarov's Avatar
tchavdarov is on a distinguished road
Here is my issue with a mesh obtained by a third party from Gridgen, exported in Fluent .cas file (I was told that) and converted to polyMesh by fluentMeshToFoam:
No errors on outut from fluentMeshToFoam:
dimension of grid: 3
Creating shapes for 3-D cells
Creating patch for zone: 3 start: 1 end: 189360 type: interior name: interior-3
Patch 3 contains solid or internal faces. Not added to boundary
Creating patch for zone: 4 start: 189361 end: 190440 type: wall name: side1-4
Creating patch for zone: 5 start: 190441 end: 192240 type: wall name: side3-5
Creating patch for zone: 6 start: 192241 end: 194400 type: inlet-vent name: inlet-vent-6
Creating patch for zone: 7 start: 194401 end: 196560 type: pressure-outlet name: pressure-outlet-7
Creating patch for zone: 8 start: 196561 end: 198360 type: wall name: side4-8
Creating patch for zone: 9 start: 198361 end: 199440 type: wall name: side2-9
Default patch type set to empty
Checking mesh
Writing mesh
End
Then I made a LES case similar to channel395 and run it. The following error occurs :
Create database
Create mesh for time = 0
--> FOAM FATAL ERROR : face 0 and 540 areas do not match by 187.749% -- possible face ordering problem
Function: cyclicFvPatch::makeWeights(scalarField& w) const
in file: meshes/fvMesh/fvPatches/derivedFvPatches/cyclicFvPatch/cyclicFvPatch.Cat line: 62.
FOAM aborting.
I apreaciate if someone can help. Could email the original .cas mesh file if let me know how to do so.
Thanks,
Boyko
tchavdarov is offline   Reply With Quote
Old   March 12, 2005, 02:55
Default Your cyclic faces are out of o
  #12
Hrvoje Jasak
Your cyclic faces are out of order - this is not picked up from the fluent file.
Mattijs has written a tool which automatically reorders cyclic patches - he'll probably be able to give you more detail...
Enjoy,
Hrv
Hrvoje Jasak
Old   March 12, 2005, 04:18
Default It is called couplePatches. It
  #13
Mattijs Janssens
mattijs is on a distinguished road
It is called couplePatches. It does not need a dictionary and you can run it with just the root and case. It should either tell you that the 'coupled patch face ordering ok' or something about morphing the mesh and will write the new mesh to a new time directory.
Just move that polyMesh/ directory back to constant/ (and check by running couplePatches again that the faces are now correctly ordered)
Mattijs
mattijs is offline   Reply With Quote
Old   May 30, 2006, 06:30
Default Hello, I am trying to use a
  #14
anne dejoan
anne is on a distinguished road
I am trying to use a pipe line mesh (theadres) created from fluent. It is a .msh extension mesh file.
The converter fluenttofoam works apparently ok
(when I use checkMesh, nothing wrong is noticed).
However I have a problem with the cyclic
condition:
When I run icoFoam on my case I have the following error:
-> FOAM FATAL ERROR : face 0 and 216 areas do not match by 3.49993% -- possible face ordering problem
From function cyclicFvPatch::makeWeights(scalarField& w) const
in file fvMesh/fvPatches/derivedFvPatches/cyclicFvPatch/cyclicFvPatch.C at line 58.
So, after having consulted the forum I applied
the command couplePatches to my case BUT it doen't create any new correct time polymesh directory. I have the following message from couplePatches:
Create time
Create polyMesh for time = 0
Using geometry to calculate face correspondence across coupled boundaries (processor, cyclic)
This will only work for cyclics if they are parallel or their rotation is defined across the origin
Mesh has coupled patches ...
Doing dummy mesh morph to correct face ordering ...
--> FOAM Serious Error :
From function cyclicPolyPatch::geometricOrder
in file meshes/polyMesh/polyPatches/derivedPolyPatches/cyclicPolyPatch/cyclicPolyPatch.C at line 541
patch:inlet : Patch inlet gets decomposed in two zones ofinequal size: 432 and 0
This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp.
Please use topological matching or adapt the featureCos() setting
Continuing with incorrect face ordering from now on!
patch:outlet : Patch outlet gets decomposed in two zones ofinequal size: 432 and 0
Mesh ordering ok. Nothing changed.
End
Thanks if someone can help me,
Anne
anne is offline   Reply With Quote
Old   February 11, 2008, 23:54
Default Yes, I got the same message. H
  #15
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Yes, I got the same message. How could I fix it?
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : couplePatches . cylinder
Date : Feb 12 2008
Time : 03:38:18
Host : daniel-desktop
PID : 12053
Root : /home/daniel/OpenFOAM/daniel-1.4.1/run/tutorials/icoFoam
Case : cylinder
Nprocs : 1
Create time
cyclicPolyPatch::order : Number of faces per zone71 71)
From function cyclicPolyPatch::order(const primitivePatch&, labelList&, labelList&) const
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 726
patch:walls : Cannot match vectors to faces on both sides of patch
half0Ctrs[0]12.733 -15.2763 5)
half1Ctrs[0]0.407746 0.272448 5)
End
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   February 12, 2008, 00:50
Default I've got it working now. Fo
  #16
lakeat's Avatar
Daniel WEI (老魏)
For i made a mistake in my *.geo file like this,
// Walls
Physical Surface("walls wall") = {98,186,216,296,516,494,480,450,146,344,370,388,40 6,252,234,172};
and now I modified it to:
// cylinder
Physical Surface("cylinder wall") = {146,344,370,388,406,252,234,172};
// Walls
Physical Surface("walls cyclic") = {98,186,216,296,516,494,480,450};
It works!
Daniel WEI
Beijing, China
Email
Old   May 28, 2008, 00:49
Default i'm also geeting this message.
  #17
Mohd Yousuf
yousuf is on a distinguished road
i'm also geeting this message. Can anyone help please
Exec : couplePatches /home/admin/intern/project cyclic_igv_case
Date : May 28 2008
Time : 10:00:49
Host : BGR-SW-99GML02
PID : 8679
Root : /home/admin/intern/project
Case : cyclic_igv_case
Nprocs : 1
Create time
cyclicPolyPatch::order : Number of faces per zone15174 0)
cyclicPolyPatch::order : Writing half0 faces to OBJ file "wall1_periodic_half0_faces.obj"
cyclicPolyPatch::order : Writing half1 faces to OBJ file "wall1_periodic_half1_faces.obj"
cyclicPolyPatch::order : Writing half0 face centres to OBJ file "wall1_periodic_half0.obj"
cyclicPolyPatch::order : Writing half1 face centres to OBJ file "wall1_periodic_half1.obj"
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 596
patch:wall1_periodic : Patch wall1_periodic gets decomposed in two zones ofinequal size: 15174 and 0
cyclicPolyPatch::order : Number of faces per zone15158 0)
cyclicPolyPatch::order : Writing half0 faces to OBJ file "wall2_periodic_half0_faces.obj"
cyclicPolyPatch::order : Writing half1 faces to OBJ file "wall2_periodic_half1_faces.obj"
cyclicPolyPatch::order : Writing half0 face centres to OBJ file "wall2_periodic_half0.obj"
cyclicPolyPatch::order : Writing half1 face centres to OBJ file "wall2_periodic_half1.obj"
patch:wall2_periodic : Patch wall2_periodic gets decomposed in two zones ofinequal size: 15158 and 0
End
Thanx in advance
yousuf is offline   Reply With Quote
Old   January 15, 2009, 02:28
Default I am wondering if the couplePa
  #18
John Wang
cwang5 is on a distinguished road
I am wondering if the couplePatches command is included in the OF 1.5. I received the message "command not found" when I typed in couplePatches
cwang5 is offline   Reply With Quote
Old   January 15, 2009, 04:28
Default couplePatches has been integra
  #19
Kati Laakkonen
kati is on a distinguished road
couplePatches has been integrated into createPatch, I think. Check release notes and/or User Guide, if I remember correctly there was some information about this issue.
Regards,
Kati
kati is offline   Reply With Quote
Old   January 15, 2009, 04:40
Default Thanks Kati, I checked the
  #20
John Wang
Thanks Kati,
I checked the release note and found out about the integration, although the User guide still listed couplePatches as a separate function. I will look around the forum and see if I can get the createPatch to work correctly. Thanks
John
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[Gmsh] Problem with mesh conversion from gmsh arussell92 OpenFOAM Meshing & Mesh Conversion 2 April 12, 2016 12:05
[GAMBIT] mesh problem in gambit...please help sandi20saze ANSYS Meshing & Geometry 4 February 9, 2014 07:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
