[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam |
January 24, 2008, 09:00 |
Hi to all,
sorry for my english; I am a newbie of OpenFoam. I have obtained several results for my problem with Fluent and now I want to work with OpenFoam using intermediate results obtained in Fluent so I want to convert .cas and .dat files to Openfoam files. I tried to use fluentMeshToFoam: it works very well with .msh file but it doesn't work with .cas and .dat files. Is it possible? Do you know some utility which do that? I want to use OpenFoam because I have the possibility to exploit a linux based pc with more RAM and so I can refine the mesh and I hope to obtain better results. So,is the tool to refine the mesh present in OpenFoam good? Is there an open source or freeware program for linux that do a refine of the mesh with a GUI? Thaks in advance, Matteo Gautero. |
January 24, 2008, 10:00 |
Hi Matteo,
I've used fluent
Francesco Boschetto
Rep Power: 17 |
Hi Matteo,
I've used fluentMeshToFoam with some .cas files and everything was ok. Which kind of errors do you have? Regards Francesco |
January 24, 2008, 10:28 |
Hi Matteo,
when I use fluen
Florian Krause
Rep Power: 17 |
Hi Matteo,
when I use fluentMeshToFoam to convert a fluent .cas file (only mesh information) I have no problems. But as I understand you correct, you want to convert your results (.cas and .dat files), than refine the mesh and run the job with OF? This conversion would be a result and mesh conversion but fluentMeshToFoam only works for mesh conversion. Somebody might correct me if I am worng regarding the fluentMeshToFoam converter Regards, Flo |
January 24, 2008, 10:30 |
Hi Matteo,
you must save case
Francesco Del Citto
Rep Power: 18 |
Hi Matteo,
you must save case as ascii to let the compiler work. And if the mesh is 3D, my suggestion is to use fluent3DMeshToFoam. About data file, I'm not aware about a converter... You can do the other way round, with foamDataToFluent (and foamMeshToFluent for the mesh). Regards, Francesco |
January 24, 2008, 10:46 |
Hi to all,
thanks for your an
Hi to all,
thanks for your answers. Yes Florian, I want to convert my results and than refine the mesh and run the case with OF. When I try to do this, the message error is: Embedded blocks in comment or unknown: ( Found end of section in unknown for several lines and then OF print this message: Number of cells: 736991 number of faces: 1524374 Number of points: 148787 0Dimension of grid: 12 (Dimension of grid: 2 Dimension of grid: 1 bDimension of grid: 3 edfDimension of grid: 1 Dimension of grid: 2 0Dimension of grid: 13 (Dimension of grid: 3 Dimension of grid: 1 Dimension of grid: 622 Dimension of grid: 24 Dimension of grid: 3 after this, OF stops. I think it's not possible to convert a .cas file after some iterations. So I will redo the itereations with the refined grid obtained by the first mesh used in Fluent. Anyway, I will try to convert the first .cas file containing the boundary conditions imposed in Fluent without iterations. Thanks, Matteo Gautero. |
January 24, 2008, 10:59 |
No, that's not true.
There is
Francesco Del Citto
Rep Power: 18 |
There is no conceptual difference between a Fluent cas file at "0" iterations and another one saved after a while. With respect to the .msh file, the .cas file contains some extra fields that the converter usually skips. As I wrote before, you MUST save your .cas file in ASCII, otherwise the converter doesn't work, and sometimes remains blocked without giving any outoput... Francesco |
January 25, 2008, 02:49 |
Hi Francesco,
you're right. I
Hi Francesco,
you're right. I tried to do what you said and it worked very well. The first messages were errors, i.e. Embedded blocks in comment or unknown ( Found end of section in unknown ) Found end of section in unknown ) but then OF read the grid and I visualized it, it was ok. Thanks to all for these explanations, Matteo. |
April 2, 2008, 10:36 |
I'm having problems processing
Michael Rangitsch
Rep Power: 17 |
I'm having problems processing a .cas file that I had run fluent on and then did a grid refinement to tighten up the grid in the boundary layer (it resulted in hanging grids). fluent3dmeshtoFoam won't process it at all -- gives me an illegal block type 37 -- that's the label on a block of text in the case file which describes the fluent models used... Any ideas?
April 2, 2008, 10:59 |
As far as I know, grid refinem
#9 |
Dragos
Rep Power: 20 |
As far as I know, grid refinement in fluent means hanging nodes, which fluent3DMeshToFoam doesn't know how to interpret.
Dragos |
April 3, 2008, 02:32 |
fluent3DMeshToFoam is able to
#10 |
Francesco Del Citto
Rep Power: 18 |
fluent3DMeshToFoam is able to handle hanging nodes (fluentMeshToFoam isn't).
If it finds an unknown block, try to open the .cas file with a text editor end remove the corresponding lines. In a fluent mesh file, each block is enclosed by ( ). Good luck! |
October 13, 2017, 20:38 |
#11 |
Aga
Rep Power: 15 |
Dear all
I tryo to save the .cas file in ASCII and convect to openfoam. But I fail The message is Found end of section in unknown Embedded blocks in comment or unknown Found end of section in unknown Found end of section in unknown Found unknown block in zone Found end of section in unknown Found unknown block in zone Found end of section in unknown Found unknown block in zone Found end of section in unknown FINISHED LEXING Could you help me how to solve it? ps: My openfoam is windows version thanks |
July 14, 2020, 12:09 |
#12 |
TWB
Rep Power: 19 |
Hi lcweng,
I got the same problem as yours. The case file was from a newer ver of Fluent. I tried to load the cas file in v16.2 and write it out in ascii and now it worked. Maybe u can try it. Thanks. |
How to Export Cas & Dat Files From Fluent | m_ridzon | FLUENT | 5 | November 13, 2018 09:42 |
Error reading the dat file | amiralia | FLUENT | 2 | April 27, 2017 00:40 |
[General] Fluent CAS and DAT file in PARAVIEW | chauhan | ParaView | 1 | April 9, 2017 00:12 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
adapted cas file for pre-adapted dat file | jrg | FLUENT | 3 | September 24, 2007 08:43 |
