[Other] How to mesh the 1st grid point
Old   October 7, 2007, 09:50
Default How to mesh the 1st grid point
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
How to mesh the 1st grid point?
I am very young to CFD world. I'm trying to use oodles to learn LES techniques.
Now I have some problems about meshing.
I saw a paper on flow over a cylinder using Fluent, its meshing guideline is like this,
Reynolds Number | Flow Regime | Yplus/First Cell Height
Re < 1000 | Laminar | First Cell Height = Cylinder Radius/24
1000 < Re < 20000 | Turbulent, Enhanced Wall Treatment | Yplus < 10
Re > 20000 | Turbulent, Standard Wall Functions | Yplus > 30
Q-1.
Why mesh like this? Is there any references on how-to mesh under LES and DNS?
Sorry, I did not find help from <grid> and <fluent>...
Q-2.
Is that mean:
If I use wall function, then I can set the 1st grid point at the place of y+=30?
If I use not wall function, then I should set the 1st grid point at the place of y+=1?
Q-3.
I heard "Laminar LES"=DNS, what does it mean? Is it mean that their mesh is identical?
Q-4.
I see that the 1st grid point is decided by the flow state, but When I predict flow around a building on a certain Re for example, the laminar and turbulence coexist around the building, then how to decide the 1st grid point?
Thanks for your time
Daniel
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   October 8, 2007, 07:13
Default Hey Daniel, I am new to LES
hadi tartoussi
hadi is on a distinguished road
Hey Daniel,
I am new to LES too, and i am running channel flows, what i can tell you is that in LES you have two calculation strategies:
-A direct near wall resolution, the first point grid should lay in the viscous sublayer (y+<5, at least 3 points needed)
-Using wall functions to resolve wall region, with the 1st point grid at the limit of the log region(y+=30).
So your mesh will depend on the calculation strategy you choose.
Hope this helps.
good luck!
Hadi
hadi is offline   Reply With Quote
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 15:17
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
