[Commercial meshers] Origin 0 0 0 has been moved while fluentMeshToFoam
Old   July 25, 2005, 12:55
Default Origin 0 0 0 has been moved while fluentMeshToFoam
Jun Ishimoto
ishimotoj is on a distinguished road
When I converted the Fluent mesh to the Foam mesh by using fluentMeshToFoam, the origin (0, 0, 0) moves different point.
Also the numbers of vertices are re-numbered and the order of the all vertices has been changed.
I want to know:
1. How to fix origin (0 0 0) while converting to the Foam mesh?
2. Why the reference pressure (pRefCell) should be set to the close point to origin?
I think that it is not necessary to place the pRefCell near the origin.
Does anyone know the countermeasure for these problems?
ishimotoj is offline   Reply With Quote
Old   July 25, 2005, 14:11
Default 1. Is this a 2D mesh? It will
Mattijs Janssens
1. Is this a 2D mesh? It will offset points (OpenFOAM meshes are 3D)
In 3D points are read in order from the fluent file.
2. No need to set it close to the origin. Any cell is fine.
Old   July 26, 2005, 07:01
Default I created the Fluent mesh as s
Jun Ishimoto
I created the Fluent mesh as same as:
/tutorials/icoFoam/cavity
There is 1-mesh thickness in the z-direction (3D).
I think this mesh is the most simple mesh, however, the origin (0 0 0) has been moved another point while the fluentMeshToFoam operation.
Old   July 26, 2005, 07:45
Default Yes the points are renumbered
henry is on a distinguished road
Yes the points are renumbered during the 1 cell layer extrusion process. If you are unhappy with this renumbering you can change fluentMeshToFoam to store the previous ordering are reapply it after the mesh conversion process but you will also have to decide how you would like the extruded points numbered.
henry is offline   Reply With Quote
Old   May 20, 2013, 04:53
Smile Moving Origin
CFD
siefdi is on a distinguished road
Hi Everyone!
This is an old thread but I have somehow a quite similar problem and hope someone could give me direction.
What I should do if I want to convert fluent mesh to openfoam format using fluent3DMeshToFoam AND move the origin from (0 0 0) to (0 0 -30).
Is it possible to do that?
note:
- it is a 3D geometry model
- I have no access to the ansys software originaly made that particular fluent mesh
- the change of origin point(0 0 0) somehow is important in my case
Any suggestion would be greatly apreciated.
Thanks in advances,
warm regards,
.:siefdi-
siefdi is offline   Reply With Quote
sampleDict not working (undefined keyword origin) jet_engine OpenFOAM Running, Solving & CFD 1 May 25, 2022 08:44
[General] Slice origin as annotation in animation bozack ParaView 6 July 27, 2018 04:37
Equation for a rotating circle outside the origin mali28 Main CFD Forum 0 November 14, 2014 06:38
Coordinate of axis origin Tang FLUENT 0 October 4, 2004 16:38
