[blockMesh] Mesh containing 9 blocks Whats wrong
Old   May 10, 2008, 09:05
Default Mesh containing 9 blocks Whats wrong
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I'm trying to set up a mesh with 9 blocks, which are connnected and form a square.
When running blockMesh I get this message about neighbour faces.
Does anybody have an idea whats wrong with the mesh?
blockMeshDict
Exec : blockMesh . .
Date : May 10 2008
Time : 14:52:31
Host : M1530
PID : 6000
Root : /home/sega/OpenFOAM/sega-1.4.1/run/surfaceTension
Case : .
Nprocs : 1
Create time
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
--> FOAM FATAL ERROR : face 2 in patch 0 does not have neighbour cell face: 4(24 28 12 8)#0 Foam::error::printStack(Foam:stream&) in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#3 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh"
#5 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh"
#6 main in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh"
#7 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/sega/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh"
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
Aborted (core dumped)
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 10, 2008, 10:48
Default Hi Niels, I wish I could gi
Hrvoje Jasak
Hi Niels,
I wish I could give you a Gold Star for this kind of a help to a new user. Thank you - your kindness is appreciated.
Hrv
Hrvoje Jasak
Old   May 10, 2008, 10:54
Default Unbelievable! Than you very v
sega's Avatar
Sebastian Gatzka
Unbelievable!
Than you very very much!!!
Old   May 10, 2008, 15:48
Default Hi Hrv Thanks for the ackno
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Hrv
Thanks for the acknowledgment. If you really insist on the Golden Star you should be welcome to bring it to Milan in July;)
@Sebastian: Your welcome, actually its my pleasure, because the thing you are doing is actually quite interesting.
Have a nice weekend both of you, I will enjoy the 25 easy breezy degrees here in Copenhagen
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 12, 2008, 09:34
Default Good day, It a first big ca
Ruben I. Mukhamadeev
benru is on a distinguished road
Good day,
It a first big case, prepared me with blockMesh.
So the same question about blockMeshDict sintax:
/attach
at patches section blockmesh sees a wrong type '(' instead of 'int', but in another cases it doesn't see any mistakes. Could anybody help to explain, what's wrong here ?
With a best regards
ruben
benru is offline   Reply With Quote
Old   May 12, 2008, 09:36
Good day,
/attach /home/rmukhamadeev/OpenFOAM/rmukhamadeev-1.4.1/run/tutorials/rhoTurbFoam/mars-b/ constant/polyMesh/blockMeshDict
With a best regards
ruben
Old   May 12, 2008, 09:37
Good day,
/attach {/home/rmukhamadeev/OpenFOAM/rmukhamadeev-1.4.1/run/tutorials/rhoTurbFoam/mars-b / constant/polyMesh/blockMeshDict}
With a best regards
ruben
Old   May 12, 2008, 09:40
Good day,
\attach {/home/rmukhamadeev/OpenFOAM/rmukhamadeev-1.4.1/run/tutorials/rhoTurbFoam/mars-b / constant/polyMesh/blockMeshDict}
With a best regards
ruben
Old   May 12, 2008, 09:42
Good day,
blockMeshDict
With a best regards
ruben
Old   May 12, 2008, 09:45
Default Sorry for mistakes with file u
Sorry for mistakes with file upload, and ask moderator to erase wrong posts.
with best regards
ruben
Old   May 12, 2008, 10:31
Default Hm, I'm a beginner too, so I'm
  #11
sega's Avatar
Sebastian Gatzka
Hm, I'm a beginner too, so I'm not familiar with all the stuff you can do with OpenFOAM, but that does look strange:
patches
patch inlet
(2 4( 99 102 101 100))
I thought that patches are created of 4 points, which are located in two brackets ( ).
So here we have 4 brackets and 6 int(eger) numbers.
So blockMesh sees a "(" instead of an integer number after the "4" ...
Or is that some special command for patches?
Old   May 13, 2008, 03:01
Default I have a box (a number of boxe
  #12
I have a box (a number of boxes) with 2 pipes.
When I generate mesh for single pipe (only for it) using
cylinderMesh.m4
I do not have any problem, but when i try to use this information for generating more complex mesh (pipe + box + pipe), blockMesh write :
Exec : blockMesh . mars-b
Date : May 13 2008
Time : 06:55:38
Host : r117-1
PID : 4148
Root : /home/ben/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam
Case : mars-b
Nprocs : 1
Create time
Creating block mesh
Creating blocks
Creating patches
--> FOAM FATAL IO ERROR : wrong token type - expected int found on line 223 the punctuation token '('
file: /home/rmukhamadeev/OpenFOAM/rmukhamadeev-1.4.1/run/tutorials/rhoTurbFoam/mars-b/constant/polyMesh/blockMeshDict::patches at line 223.
From function operator>>(Istream&, int&)
in file primitives/int/intIO.C at line 74.
FOAM exiting
So I don't understand what's wrong.
Old   July 24, 2008, 08:02
Default what is the patch for. can ne1
  #13
mayank gupta
mgz1985 is on a distinguished road
what is the patch for. can ne1 xplain. Also, i m completely new to openfoam. I m trying to write a mesh.
the first thing i wish i knew is what are so many files in the polymesh directory for. because i understand points are vertices, neighbours are adjacent nodes and faces are built by patching the nodes in a proper sequence. but what is boundary and patches. I cant understand. And especially moving boundary? should that not be dynamic boundary? can ne1 help?
please.
mgz1985 is offline   Reply With Quote
Old   July 26, 2008, 05:56
Default how do we number neighors and
  #14
mayank gupta
how do we number neighors and cells in polyMesh directory
can ne1 xplain with n xample. I read both the user and programmers guide but to no avail and even this forum has left me confused
http://www.cfd-online.com/OpenFOAM_D...es/1/3958.html
i have a simple block with 18 vertices and 16 faces with one internal faces can neone help
Old   July 26, 2008, 07:49
Default Hi Mayank You should look i
  #15
ngj
Hi Mayank
You should look into the tutorials. Start off with the cavity-case and see how the mesh is generated using blockMesh.
The boundary file is also generated by blockMesh and contains information on the location of the different boundaries in the mesh based on face-ID.
As a start you do not need to know how the neighbour and owner is numbered. When you have got a feel of running OF you will be prepared to go farther.
In my case I realized the structure of the polyMesh files (as generated by blockMesh) by looking at a 3x3x1 cavity mesh.
Best regards,
Niels
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
