[blockMesh] Tutorial for Creating Simple 3D Meshes
Old   August 6, 2007, 17:05
Default Tutorial for Creating Simple 3D Meshes
jonlemur
Hello, I am trying to simulate fluid flow around a cylinder and around a sphere. I am very new to OpenFOAM (and CFD in general), and needing to get some basic results fast. So I wanted to see if anyone could recommend a tutorial for creating spheres and cylinders. And perhaps a tutorial on how to run some simulations on the geometries I make. I looked over the tutorials on the OpenFOAM website, but nothing caught my eye that looked like it taught how to make 3D geometries; everything seemed geared toward 2D.
Thanks for any help you can give.
Old   August 6, 2007, 19:28
Default 1. Read User Manual. - that se
paka is on a distinguished road
1. Read User Manual. - that sentence includes all information which you need.
2. Use external software (like Gambit) to create your meshes.
paka is offline   Reply With Quote
Old   August 6, 2007, 19:50
Default Jon, Search the forum for f
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Jon,
Search the forum for flow past cylinder. Many people have done it. You should be able to use blockMesh to create and mesh your simple geometry with ease. Check out www.openfoamwiki.net as well. Go over the lid-driven cavity tutorial to grasp some basics. Good Luck!
msrinath80 is offline   Reply With Quote
Old   August 7, 2007, 18:11
Default Thanks for the replies. I'll
jonlemur
Thanks for the replies. I'll try that stuff out asap.
Old   August 8, 2007, 13:20
Default Hi, Personally, I found tha
Pei-Ying Hsieh
hsieh is on a distinguished road
Personally, I found that cgx (www.CalculiX.de) is easier to use than blockMesh. It gives you the ability to visualize what you are building + the mesh. It also exports to OpenFOAM mesh format.
Pei
hsieh is offline   Reply With Quote
Mapping (interpolation) between two meshes Ebrahim OpenFOAM Programming & Development 2 June 15, 2020 13:31
[Tutorials] New Dakota - OpenFOAM Coupling Tutorial Tobi OpenFOAM Community Contributions 0 October 9, 2016 17:19
How can I put the data of adpated meshes on the original unadapted meshes? xh110120 FLUENT 2 March 11, 2016 02:00
[PyFoam] Simple tutorial for exporting some PyFoam data (variable) to OpenFoam Asghari_M OpenFOAM Community Contributions 0 June 20, 2015 15:16
