[blockMesh] BlockMesh error
Old   April 13, 2006, 15:59
Default BlockMesh error
Hrvoje Jasak
hjasak will become famous soon enough
So far, you've got a bunch of points, but only one block:
hex (0 1 2 3 4 5 6 7)
(50 50 1)
simpleGrading (1 1 1)
Since the block only uses points 0-7, it is clear that face 4(0 16 17 3) does not have a block it belongs to, which is as error.
Which part of the error message don't you understand?
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   April 13, 2006, 16:10
Default It's hard for me to explain wh
Shelley Nation
shellbell1999 is on a distinguished road
It's hard for me to explain what i want the mesh to look like but basically its a cube and points 16 and 17 lie on the left wall of the cube. The block I defined is the entire cube and I assumed that in defining this since 16 and 17 were on the cube it would be alright. So I'm guessing this isn't true?
And the main part of the error is:
--> FOAM FATAL ERROR : face 0 in patch 0 does not have neighbour cell face: 4(0 16 17 3)
what is a cell face?
Thanks
shellbell1999 is offline   Reply With Quote
Old   April 13, 2006, 16:24
Default Not true - read the section in
Hrvoje Jasak
Not true - read the section in the manual about mesh generation. You will need to define more than one block, or create one block and then re-patch the boundaries to grab the face you want to catch. Currently, blockMesh only allows you to grab the whole side of a block to define a boundary patch.
Try thinking about how the code is supposed to do its job: the only way to "find out" that your points ar on the surface would be through floating point comparisons, which would be very very bad indeed.
Hrv
Hrvoje Jasak
Old   April 13, 2006, 16:29
Default Ahhh I did not know that. Than
Shelley Nation
Ahhh I did not know that. Thank you very much. I'll try that
Shelley
Old   April 19, 2006, 09:36
Default Oops nevermind. Apparently I j
Shelley Nation
Oops nevermind. Apparently I just couldn't see that extra parenthases.
Old   August 24, 2012, 07:22
Default Another causes for the same message error?
Paula
curiosity is on a distinguished road
I´ve made a geometry and I´ve got the same error:
FOAM FATAL ERROR:
face0 in patch 11 does not have neighbour cell face: 8(160 161 162 163 164 165 166 167)
The question is, I know the order to name the vertices in a block and I´ve reviewed all my vertices and blocks... Could it be another cause to this message error?
The face0 of the cell is next to a part of another bigger cell... Could it be the problem?
Thanks!
curiosity is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
