[Gmsh] GmshToFoam
Old   November 30, 2007, 08:32
Default GmshToFoam
Varun Vikas
varun is on a distinguished road
Hi
I am trying to convert the "CubeVer1.msh" (present in $FOAM_UTILITIES/mesh/conversion/gmshToFoam/). I created a case gmshTest in $FOAM_RUN/tutorials/icoFoam/ and then executed the following command
gmshToFoam $FOAM_RUN/tutorials/icoFoam/ gmshTest $FOAM_RUN/tutorials/icoFoam/gmshTest/CubeVer1.msh
and got the following output
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : gmshToFoam /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/ gmshTest /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/gmshTest/CubeVer1.msh
Date : Nov 30 2007
Time : 18:49:21
Host : sarkeshwar
PID : 30400
Root : /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/
Case : gmshTest
Nprocs : 1
Create time
Read nVerts:167
Read nElems:838
Mapping region 27 to Foam patch 0
Mapping region 28 to Foam patch 1
Mapping region 29 to Foam patch 2
Mapping region 30 to Foam cellZone 0
Cells:
total:622
hex :0
prism:0
pyr :0
tet :622
Patches:
Patch Size
0 36
1 36
2 144
CellZones:
Zone Size
0 622
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 573
Found 216 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
Finding faces of patch 1
Finding faces of patch 2
FaceZones:
Zone Size
Writing zone 0 to cellZone cellZone_0 and cellSet
End
After running the solver, I use the followign command for opeining the case in paraFoam
paraFoam $FOAM_RUN/tutorials/icoFoam/ gmshTest
When I click accept, paraFoam crashes with folowing error:
--> FOAM FATAL IO ERROR : attempt to read beyond EOF
file: /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/0/p::internalField at line 30.
From function ITstream::read(token& t)
in file db/IOstreams/Tstreams/ITread.C at line 70.
FOAM exiting
I am new to OpenFoam. I will be extremely grateful if somebody could help.
Thanks
Varun
varun is offline   Reply With Quote
Old   January 30, 2012, 13:03
Default gmshToOpenFoam
Goutam Saha
Goutam is on a distinguished road
Originally Posted by varun View Post
Hi
Date : Nov 30 2007
Time : 18:49:21
Host : sarkeshwar
PID : 30400
Case : gmshTest
Nprocs : 1
Create time
Read nVerts:167
Read nElems:838
Cells:
total:622
hex :0
prism:0
pyr :0
tet :622
Patches:
Patch Size
0 36
1 36
2 144
CellZones:
Zone Size
0 622
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
FaceZones:
Zone Size
End
FOAM exiting
Thanks
Varun
Hi
Varun, I am new user of OpenFOAM and I have the same problem. How I will solve this? COuld you please help me?
Thanks
Goutam
Goutam is offline   Reply With Quote
Old   February 1, 2012, 03:27
GregorS's Avatar
Gregor Seljak
GregorS is on a distinguished road
Maybe you forgot some semicolon - ';' at the end of line in you 0/p file.
Additionally, when executing gmshToFoam on you *.msh file, you need to do some minor changes in your constant/polymesh/boundary file (change patch types, ...).
So for start, please post your:
-/home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/0/p
-/home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/constant/polymesh/boundary
files, to see if there are some corrections needed.
GregorS is offline   Reply With Quote
Old   February 1, 2012, 05:36
Default Gmsh
Goutam Saha
Dear friends,
Could you please see my attached files. You will find my cubic.geo, cubic.msh, and 0/p , 0/U files.
Thanks
Old   March 13, 2012, 03:24
matt.mech.eng is on a distinguished road
Was there a solution to this problem I am having similar difficulties, I tried to copy the bubbleFoam tutorial folder and copied my .msh file into the case directory and ran gmshToFoam from this directory.
I get the following output:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.1-51f1de99a4bc
Exec : gmshToFoam approx_profile.msh
Date : Mar 13 2012
Time : 19:04:53
Host : matthew-desktop
PID : 3326
Case : /home/matthew/Documents/FYP/OpenFOAM/TEST_CASE_1/PARABOLIC_TANK
nProcs : 1
Create time
Starting to read mesh format at line 2
Read format version 2.2 ascii 0
Starting to read points at line 5
Vertices to be read:1032
Vertices read:1032
Starting to read cells at line 1040
Cells to be read:5271
Unhandled element 15 at line 1042
Unhandled element 15 at line 1043
Unhandled element 15 at line 1044
" " " " " 1045
Unhandled element 15 at line 1053
Unhandled element 1 at line 1054
Unhandled element 1 at line 1055
" " " " " 1056
Unhandled element 1 at line 1225
Mapping region 0 to Foam patch 0
Mapping region 0 to Foam cellZone 0
Cells:
total:3219
hex :0
prism:0
pyr :0
tet :3219
CellZones:
Zone Size
0 3219
Skipping tag at line 6314
Patch 0 gets name patch0
--> FOAM Warning :
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614
Found 1868 undefined faces in mesh; adding to default patch.
FaceZones:
Zone Size
End
What corrections would be required in ploymesh/boundary and 0/p files?
What are unhandled elements? And what has caused undefined faces to occur?
I forgot to mention running paraFoam crashed and I got the following error:
--> FOAM FATAL IO ERROR:
size 1875 is not equal to the given value of 3219
file: /home/matthew/Documents/FYP/OpenFOAM/TEST_CASE_1/PARABOLIC_TANK/0/p from line 17 to line 1921.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file lnInclude/Field.C at line 236.
FOAM exiting
Cheers
matt.mech.eng is offline   Reply With Quote
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 10:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 03:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 07:36
