[snappyHexMesh] 2D snappyHexMesh
Old   January 19, 2010, 04:17
Default 2D snappyHexMesh
wong
wind_fyp is on a distinguished road
Dear all,
I try to simulate wind flow throung a sing building in OpenFOAM, in order to save some running time, I simulate it as a 2D case.
However, the snappyhexMesh is not applicable in 2D simulation because it will not only refine in x and y direction, but also in z direction, there make my blockMesh has more then one layer of cell in z direction, do someone have some tool for 2D snappyHexMesh? Or do someone have idea for my question?
Thx,
wind_FYP
wind_fyp is offline   Reply With Quote
Old   January 20, 2010, 06:14
Default extrudeMesh
Michael Roth
roth is on a distinguished road
Perhaps you could snappyHexMesh your geometry and then use extrudeMesh to extrude one layer from the surface representing your 2D geometry. Just keep the layer.
Mike
roth is offline   Reply With Quote
Old   January 21, 2010, 04:37
wong
thx, Mike
But can you tell me how to use 'extrudeMesh ' in detail, because I have not used before.
wind_FYP
Old   September 27, 2010, 13:00
ms
anothr_acc is on a distinguished road
Hi Wind_fyp,
Did you get your job working? I'm in the same position and am wondering what the best approach is. There seems to be a distinct lack of two-dimensional snappyHexMesh posts!
Cheers, Mark.
anothr_acc is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
