February 2, 2010, 16:28 |
StarToFoam error
Arton Kosumi
Hello OpenFOAm users,
I'm trying to use the StarToFoam converter but I get the following error and all the things I have tried give me the same error. I have put this qusetion also in the "Using starToFoam" Forum but nobody has replyed me.. I hope somebody can help me here!! The Error: xxx453:~/OpenFOAM/arton-1.6/starcd/kubus> starToFoam Kubus /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : starToFoam Kubus Date : Jan 28 2010 Time : 11:37:34 Host : xxx453 PID : 9369 Case : /perm1/arton/OpenFOAM/arton-1.6/starcd/kubus nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Number of points = 7655 Number of cells = 5682 Star region 457 with type WALL is now Foam patch 0 Star region 456 with type WALL is now Foam patch 1 Star region 405 with type ATTA is now Foam patch 2 Star region 404 with type ATTA is now Foam patch 3 Star region 458 with type WALL is now Foam patch 4 Star region 430 with type INLE is now Foam patch 5 Star region 429 with type INLE is now Foam patch 6 Star region 410 with type ATTA is now Foam patch 7 Star region 409 with type ATTA is now Foam patch 8 Star region 451 with type WALL is now Foam patch 9 Star region 427 with type INLE is now Foam patch 10 Star region 426 with type INLE is now Foam patch 11 Star region 402 with type ATTA is now Foam patch 12 Star region 401 with type ATTA is now Foam patch 13 Star region 435 with type WALL is now Foam patch 14 Star region 434 with type WALL is now Foam patch 15 Star region 407 with type ATTA is now Foam patch 16 Star region 406 with type ATTA is now Foam patch 17 Star region 432 with type WALL is now Foam patch 18 Star region 431 with type WALL is now Foam patch 19 Star region 442 with type WALL is now Foam patch 20 Star region 412 with type ATTA is now Foam patch 21 Star region 417 with type INLE is now Foam patch 22 Star region 201 with type INLE is now Foam patch 23 Star region 437 with type WALL is now Foam patch 24 Star region 422 with type INLE is now Foam patch 25 Star region 441 with type WALL is now Foam patch 26 Star region 411 with type ATTA is now Foam patch 27 Star region 416 with type INLE is now Foam patch 28 Star region 436 with type WALL is now Foam patch 29 Star region 421 with type INLE is now Foam patch 30 Star region 445 with type WALL is now Foam patch 31 Star region 415 with type ATTA is now Foam patch 32 Star region 420 with type INLE is now Foam patch 33 Star region 440 with type WALL is now Foam patch 34 Star region 425 with type INLE is now Foam patch 35 Star region 444 with type WALL is now Foam patch 36 Star region 202 with type INLE is now Foam patch 37 Star region 419 with type INLE is now Foam patch 38 Star region 414 with type ATTA is now Foam patch 39 Star region 439 with type WALL is now Foam patch 40 Star region 424 with type INLE is now Foam patch 41 Setting size of boundary to 42 #0 Foam::error:rintStack(Foam::Ostream&) in "/perm1/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/perm1/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::List<int>:perator=(Foam::List<int> const&) in "/perm1/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/starToFoam" #4 starMesh::readBoundary() in "/perm1/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/starToFoam" #5 starMesh::starMesh(Foam::fileName const&, Foam::Time const&, double) in "/perm1/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/starToFoam" #6 main in "/perm1/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/starToFoam" #7 __libc_start_main in "/lib/libc.so.6" #8 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Segmentation fault xxx453:~/OpenFOAM/arton-1.6/starcd/kubus> PLEASE if you can help me!! Thank you |
February 4, 2010, 04:38 |
#2 | |
Mark Olesen
Rep Power: 40 |
The star4ToFoam converter at least does a better job of handling unused points. First verify that the checks in proSTAR are all okay, then save it in the version 4.x format and see if that solves your problems. You might also consider the ccm->foam converter. When you write the ccm file from proSTAR, you might discover errors in your model along the way. |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
