[mesh manipulation] transformPoints destroyed my mesh |
Robert Langner
Rep Power: 16 ![]() |
Hello dear Foamers!
The basic: I'm working with a meshing tool which handles with millimeters (Salome) and the ideasUNVToFoam interpretes it as meters, so it needs to be "convertToMeters" with transformPoints (-scale). My case: A flow though a blood artery bifurcation at millimeter scale. The walls are really "natural" shaped so I not expected the best mesh quality (hexahedric mesh). I ran checkMesh before scaling: Everything was "OK". Non-orthogonality was pretty high (=60), but below the limit (=70). After scaling (transformPoints -scale '(0.001 0.001 0.001)') the second check gave the following results: - non-orthogonality raised to 150 - wrong oriented faces - skewness jumped above 13.000.000 - and with smaller scaling even negative cell volumes occur I'm copletely perplexed! Correct me if I'm wrong, but a simple scaling should have no effect on mesh quality. Please could someone give me some advise how to keep my mesh quality when scaling or at least by what this quality lost is caused ? Thanks in advance, Robert |
Robert Langner
I found the point where the problem occured on my own!
The file format precision reducing with the distance between model and coordinate triangle. Bye Robert |
Artur
Rep Power: 0 ![]() |
I have the same Issue and didn't understand the Solution. Perhaps you are still here Robert and can describe your solution method ?! I have the same Problem. The maxskewness value rises after downscaling with transformPoints. Another way I tried was to scale the Mesh in Salome and Output it to Openfoam. Both ways are giving the same big skewness value. Without scaling: maxskewness is about 0.6 After scaling: maxskewness is about 3.4 So I tried this with an normal cube. Building and Meshing in Salome with an Cellsize of 0.01mm. Output with unv to Openfoam -> All Fine. But with an Cellsize of 0.001mm I get big skewness values. Anybody an idea ? I don't think its logical because a normal cube must have an skewness value of about 0. Right ? Artur |
Robert Langner
Hi Artur,
sorry for the late response, I thought this thread was dead/done. The unv file format saves coordinates in a scientific form like: cell_coordinate1 = 0.001100 * 10^0 cell_coordinate2 = 0.003200 * 10^0 These coordinates are near the coordinate center. But my model was small and far far away from the coordinate center. So if we move the points above i.e. 1000 units away from the center, the values SHOULD look like: cell_coordinate1 = 1.000001100 * 10^3 cell_coordinate2 = 1.000003200 * 10^3 But the decimal places are limited (.6 ?). So whats really saved is: cell_coordinate1 = 1.000001 * 10^3 cell_coordinate2 = 1.000003 * 10^3 As you can see the smaller decimal places are cut off and the model values are affected. If we would move the point even more away cell_coordinate1 = 1.000000 * 10^4 cell_coordinate2 = 1.000000 * 10^4 the values no longer differ and the cell thickness would be zero. Thats what I meant with "The file format precision reduces with the distance between model and coordinate triangle." With keeping my model close to the coordinate center, I avoided this problem. Robert |
Artur
Hi Robert,
I've hoped this thread is not done ![]() So now I understand your precision reason. And for that reason I think it's a bug. I am not upscaling but downscaling the Mesh. Saving the Coordinates in the *.unv Format is done by 16 digits. Here is an Example of a Coordinate for my Mesh before and after the Scaling: -2.3400000000000000E+02 -> scale 1E-06 -> -2.3400000000000000E-04 So I don't think I'm loosing some Information about the Mesh. Anyway the Skewness rises from for example 1.3 to 3.7 after Scaling. I've looked into the Source Code and as long as I understood the computation the Skewness don't have to change. Since my computations work it is not a big problem. I only want to recognize the failure in my work. Artur |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 05:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
