[Commercial meshers] define porous zone in gambit
Old   July 7, 2010, 11:50
Default define porous zone in gambit
Michel
Michel_HB is on a distinguished road
Hello FOAMers,
I want to simulate flow through and around porous media.
I created a mesh in block-mesh and blockmesh defines the porous zone in the cellZone-file.
Now I want to build the mesh with gamit and then export the mesh to OF.
But how can I define a porous zone with Gambit?
In the attached file you can see the channel with the porous block inside.
Has anyone an idea how to solve the problem?
thanks a lot, have a good day....
Michel
Michel_HB is offline   Reply With Quote
Old   November 26, 2011, 06:00
Daniele
Daniele111 is on a distinguished road
Hi I have the same problem! How did you solve it? Thanks Daniele
Daniele111 is offline   Reply With Quote
Old   September 17, 2012, 06:26
zaynah K.
zaynah04 is on a distinguished road
hi Micheal
had you resolved that problem?
Regards
zaynah
zaynah04 is offline   Reply With Quote
Old   September 19, 2012, 02:16
-mAx-'s Avatar
Maxime Perelli
in Gambit you have to isolate the volume which will be treated as porous.
For that, use split tool.
Once you volume is splitted, you can assign it as porous zone in the specify continuum types panel
http://aerojet.engr.ucdavis.edu/gamb...zone_cont_type
Old   February 26, 2015, 04:13
Default Porous continuum in GAMBIT
myaccount is on a distinguished road
Hi MAx,
I want to solve flow through porous medium problem.For this I need to create a porous continuum.I am currently working with GAMBIT 2.4.6,in which I found only fluid and solid continuum.Now how to create a porous continuum in GAMBIT 2.4.6? I have also seen the following link...
I still could not fix the problem.Please suggest me the correct path.
myaccount is offline   Reply With Quote
Old   February 26, 2015, 06:22
-mAx-'s Avatar
Maxime Perelli
Define your porous zone as fluid in Gambit , (but separated as the default domain)
Once your mesh is imported in Fluent, define the fluid zone as porous-jump instead of interior
Old   February 26, 2015, 07:01
Hi Max,
Thanks for the reply.I have tried the method you suggested.I still have a problem in the procedure you mentioned.
I have defined the zone of porous medium as fluid in GAMBIT( I named it as "middle", with continuum as fluid in GAMBIT.).
When I transferred this to FLUENT, in boundary conditions panel, in the boundary conditions panel, a default interior 013 is shown (the mesh in that zone) also there is "middle" shown as fluid.
My question is:
Should I change this default interior 013 to "porous jump" or
should I change the zone of "middle" from fluid to porous?
Which is correct?
Old   February 26, 2015, 07:17
-mAx-'s Avatar
Maxime Perelli
According to this tutorial: https://www.sharcnet.ca/Software/Flu...tg/node113.htm
I would say, you have to choose "middle"
Old   February 26, 2015, 07:41
Hi MAx,
Thanks a lot for the reply.I will implement this.
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 08:02
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Porous zone input properties chaudhry_hashim FLUENT 0 September 10, 2014 02:48
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
