[Commercial meshers] Error in fluentMeshToFoam
Old   September 13, 2010, 05:58
Default Error in fluentMeshToFoam
dewebba is on a distinguished road
Hello everybody,
I am trying to convert a fluent mesh into openfoam format. It works fine for simple geometries as a cylinder.
However when I try to convert a axisymmetric wedge mesh (one 3D-Layer of hexas/prisms) I get the following error:
| \\ / O peration | Version: 1.6 |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : fluentMeshToFoam fluent.msh
Date : Sep 13 2010
Time : 11:45:29
Host : defoe
PID : 7811
Case : /usr/defoe/expsm/OpenFOAM/expsm-1.6/run/MB_2DBlock
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Dimension of grid: 3
Number of points: 139500
Reading points
Number of cells: 69276
Other readCellGroupData: c 1 10e9c 1 0
Reading mixed cells
number of faces: 277327
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading uniform faces
Reading mixed faces
Reading mixed faces
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/defoe/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/usr/defoe/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 yyFlexLexer::yylex() in "/usr/defoe/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#4 main in "/usr/defoe/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
Any help would be appreciated!
Daniel
dewebba is offline   Reply With Quote
Old   September 22, 2010, 09:02
I believe, that I have found the solution to the problem, which I would like to share:
The problem was, that in the mesh, which I generated using ICEM, some vertices were set to be periodic (Blocking -> Edit Block -> Periodic Vertices). After removing the periodicity of the vertices I was able to convert the mesh.
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" preibie OpenFOAM Meshing & Mesh Conversion 28 March 29, 2017 04:56
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam MichaelD OpenFOAM Meshing & Mesh Conversion 1 July 2, 2014 06:34
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam sasanghomi OpenFOAM Meshing & Mesh Conversion 2 March 29, 2013 07:58
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 16:56
[Commercial meshers] Error fluentMeshToFoam loneboard OpenFOAM Meshing & Mesh Conversion 26 February 6, 2009 10:20
