September 17, 2010, 04:17 |
basic understanding of sHM
Rep Power: 18 |
Hi guys,
after working with sHM for a while and didn't get the results that I needed I have to ask you some questions, to get a better basic understanding. The case I'm working on is comparatively simple. To simulate the flow of water around a floating structure and get the resulting wave pattern I want to use interFoam. The geometry of the solid that shall be examined I have as an .stl file and stored in a trisurface folder. And finally the background mesh is created with blockMesh (simple box with elements of an aspect ratio close to one). Everything is done according to the guidelines of of.com So now it comes to the snappyHexMeshDict file where I don't get every parameter, even after reading the manual more than twice. The questions that arose: Which is the parameter that defines the location of the stl geometry in the background mesh? I know there is a parameter called location in mesh, but what exactly is his function and where is the point he is located in the stl file (if this is the right parameter for that issue) How do I have to understand the splitting parameter? There is a level specification, but can I assume that level 1 splits one element in 8 sub elements level 2 in 64 and so on? What has the parameter locationInMesh with the cell removal to do? I hope these questions are not too basic thanks for your trouble Colin Edit: I got the snappyHexMesh comand running without any errors but viewing the mesh with paraFoam I couldn't find my floating structure within that mesh. Last edited by colinB; September 17, 2010 at 06:17. Reason: forgott something to mention |
October 6, 2010, 08:17 |
Rep Power: 18 |
Hi
for those of you who have the same questions like me, I could answer some of them and I want to share. I know that some things might look trivial especially when you have been working with sHM for some time, but though these answers might help the one or other user to get little easier into sHM. How do I locate a stl geometry in my background mesh generated with blockMesh: Both meshes have a (0 0 0) coordinate and these will be on top of each other when combined in the sHM mesh. How can I view the total mesh after running sHM and how is the calculation done with the sHM Mesh and not just with the background mesh: always use the command: snappyHexMesh -overwrite and not just snappyHexMesh. This will overwrite the mesh information in the relevant folders and you can see/calculate now with the mesh generated by sHM What is the parameter locationInMesh for: place this point in the part of the Mesh you want to keep (I know it is explained very well in the documentation) so far my cognition regards Colin |
basic, knowledge, parameters, shm, snappyhesmeshdict |
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. | Laika | OpenFOAM Meshing & Mesh Conversion | 1 | September 8, 2016 04:09 |
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? | ADGlassby | OpenFOAM Meshing & Mesh Conversion | 18 | June 18, 2013 06:07 |
[snappyHexMesh] troubles with sHM and parallel | Tobi | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2012 17:54 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 00:51 |
Basic Understanding | Abduri | CFX | 8 | March 7, 2009 06:12 |
