[snappyHexMesh] sHM - reconstructPar
Like Tree19Likes
  • 12 Post By Tobi
  • 1 Post By Tobi
  • 4 Post By TobM
  • 2 Post By TobM
Old   November 10, 2010, 08:12
Default sHM - reconstructPar
Tobi's Avatar
Tobias Holzmann
i run snappy with 6 cores. After it, i will reconstruct it again. But how?!
tobi@tobi:~/OpenFOAM/tobi-1.7.x/run/teg$ reconstructPar -constant
|  \\    /   O peration     | Version:  1.7.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.x-2154baf2ac24
Exec   : reconstructPar -constant
Date   : Nov 10 2010
Time   : 14:10:51
Host   : tobi
PID    : 2687
Case   : /home/tobi/OpenFOAM/tobi-1.7.x/run/teg
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/tobi/OpenFOAM/tobi-1.7.x/run/teg/processor0/0/polyMesh/pointProcAddressing at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
the file "pointProcAddressing" is missing.
Any ideas.
Tobi
Old   November 10, 2010, 09:53
Steven van Haren
stevenvanharen is on a distinguished road
Why do you use -constant?
Have you tried it without?
stevenvanharen is offline   Reply With Quote
Old   November 10, 2010, 10:16
Tobi's Avatar
Tobias Holzmann
yes i ve tried it with all tags.
but i realized, that i need "reconstructParMesh" instead of reconstructPar after mesh generation. I am so stupid
tobi
Old   January 28, 2011, 08:43
Sandy Lee
sandy is on a distinguished road
Originally Posted by Tobi View Post
tobi
Hi Tobi, what is the difference between reconstrucParMesh and reconstructPar?
sandy is offline   Reply With Quote
Old   January 28, 2011, 09:04
Tobi's Avatar
Tobias Holzmann
hi Sandy,...
if you split your mesh to solve sHM with more cores you have to reconstruct your mesh with the command
reconstructMeshPar
if you run your equation with more cores you have to use after finishing
reconstructPar
Couse you have to reconstruct the mesh and all other files like (p / U / T / etc.)
Hope it 's helpful.
-> reconstructPar for solver
-> reconstructParMesh for sHM
I hope its correct - but i am certain sure about it.
Tobi
Guimloute likes this.
Old   January 28, 2011, 21:57
Sandy Lee
Hi Tobi, thank you for your reply. However, now I use lines step by step as follows:
1. blockMesh
2. snappyHexMesh
3. decomposePar
4. mpirun -np 8 interFoam -parallel
Could you tell me which one I should use, reconstructPar or reconstructParMesh? Waiting for your help again.
Sandy
Old   January 29, 2011, 07:42
Tobi's Avatar
Tobias Holzmann
1. blockMesh
2. snappyHexMesh
3. decomposePar
Sandy
hi
5. reconstructPar
I added a bash file you can execute it with ./solve and change it - you should use your solver
http://www.file-upload.net/download-...solve.zip.html
Tobi
Old   January 19, 2016, 08:05
Stephanie
stephie is on a distinguished road
Hello Tobi,
maybe you can help me. I got the same error message:
cannot find file
file: /home/stephanie/Schreibtisch/FFW_E2/processor0/0.001/polyMesh/pointProcAddressing at line 0.
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I am using a prepared SHM. Fore my case I am using interDyMFoam with an adaptiveMesh at the phase boundary.
I run these commands:
setFields >> log.setFields
decomposePar >> log.decomposePar
mpirun -np 2 interDyMFoam -case /home/stephanie/Schreibtisch/FFW_E2/ -parallel >> log.interDyMFoam
reconstructPar >> log.reconstructPar
There seemed to be no problem until the command reconstructPar. There are both processor-folders with the timesteps inside.
Might you have any idea, where I did a mistake?
I would be very grateful for your help.
Thank you and best regards,
Stephie
stephie is offline   Reply With Quote
Old   January 19, 2016, 08:22
TobM is on a distinguished road
Hi Stephie,
with adaptive mesh refinement you have each time step a different mesh.
Use
1. reconstructParMesh for the mesh for each time step
2. reconstructPar for the fields
Best regards
Tobias
dokeun, Pagoda, acaist and 1 others like this.
TobM is offline   Reply With Quote
Old   April 10, 2017, 18:12
Default reconstructPar not reconstructing time 0
Jorge Rivas Ordenes
Coke Rivas Ordenes is on a distinguished road
Hi Tobi and Stephie,
Hope you can help me out with something that has been keeping my mind busy, related with reconstructing the case after running in it parallel.
The base case has the directories: 0.orig (with the respective fields), constant and system. Pretty standar. I run the simulation (PISO LES solver), decomposing the domain and reconstructing it, with the following Allrun script:
 #!/bin/sh
cd ${0%/*} || exit 1    # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Make dummy 0 directory
mkdir 0
runApplication blockMesh
cp system/decomposeParDict.hierarchical system/decomposeParDict
runApplication decomposePar
cp system/decomposeParDict.ptscotch system/decomposeParDict
runParallel snappyHexMesh -overwrite -parallel
find . -type f -iname "*level*" -exec rm {} \;
ls -d processor* | xargs -I {} rm -rf ./{}/0
ls -d processor* | xargs -I {} cp -r 0.orig ./{}/0 $1
runApplication funkySetFields -case processor0 -time 0
mv log.funkySetFields log.funkySetFields1
runApplication funkySetFields -case processor1 -time 0
mv log.funkySetFields log.funkySetFields2
runApplication funkySetFields -case processor2 -time 0
mv log.funkySetFields log.funkySetFields3
runApplication funkySetFields -case processor3 -time 0
mv log.funkySetFields log.funkySetFields4
runParallel pisoFoam
runApplication reconstructParMesh -constant -mergeTol 1e-6
It all goes splendid (with some issues, but the overall outcome is positive), but i have encounter a problem.
reconstructPar
(or reconstructParMesh, not sure which of both) does not reconstruct time 0 (initial values), but it does it perfectly with the following time step.
I have already deleted the lines
mkdir 0
and re-run it all over again, but the problem persist; time 0 is not reconsrtucted.
Any thoughts? Thanks in advance for the time you might take reading my question.
Coke Rivas Ordenes is offline   Reply With Quote
Old   April 11, 2017, 02:25
reconstructPar has the option -withZero, use it like this:
reconstructPar -withZero
dokeun and Coke Rivas Ordenes like this.
Old   April 11, 2017, 07:45
Jorge Rivas Ordenes
Thank you very much! I tried -time 0 before asking, but i didn't encounter (or thought) the right way to use it so i received nothing but error messages . Thank you again, i will try it out very soon.
Old   May 13, 2020, 11:27
Huy Quang Dong
cunconbkhp is on a distinguished road
Hi tobi! I've run my case in oepnFoam 7 with the order below :
runApplication surfaceFeatures
runApplication decomposePar -copyZero
runParallel setRefinedFields
to recompose the case, i've trie reconstrucParmesh and reconstrucPar, event for each time step with a script :
#!/bin/bash
timeList=$(ls processor0/ | awk '$1!="constant"');
for line in $timeList
do
echo "Recontructing mesh for t = "$line" s";
reconstructParMesh -time $line > logTmp;
echo "Reconstructing fields for t = "$line" s";
reconstructPar -time $line > logTmp;
echo "";
done
rm logTmp;
but i have alaway the same error : processor0/0/polyMesh/pointProcAddressing not exist.
Could you please give me a hint!
cunconbkhp is offline   Reply With Quote
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. Laika OpenFOAM Meshing & Mesh Conversion 1 September 8, 2016 04:09
reconstructPar nor working Priya Somasundaran OpenFOAM Post-Processing 2 January 28, 2016 14:37
[snappyHexMesh] shm in parallel with simple decomposition mihaipruna OpenFOAM Meshing & Mesh Conversion 6 July 16, 2015 04:55
[snappyHexMesh] troubles with sHM and parallel Tobi OpenFOAM Meshing & Mesh Conversion 1 August 30, 2012 17:54
reconstructPar and a high number of snapshots fs82 OpenFOAM Programming & Development 2 April 18, 2012 04:37
