[snappyHexMesh] snapEdge - failure
Like Tree2Likes
Old   January 30, 2011, 06:01
Default snapEdge - failure
Tobi's Avatar
Tobias Holzmann
i wanna test the snapEdge tool and downloaded it from the wiki and installed it correctly.
If i run snapEdge i got a error message that he can 't read the "stl" file.
--> FOAM FATAL ERROR:
Cannnot read "inlet.stl"
    From function triSurface::read(const fileName&, const word&, const bool)
    in file triSurface/triSurface.C at line 371.
FOAM exiting
does someone know these error message ?
I ve had a look at the triSurface.C file but there is just the error-report line.
thanks
Tobi
Old   January 30, 2011, 06:30
Tobi's Avatar
Tobias Holzmann
Okay - prolbem solved
the STL has to be in the "case" dictionary. Not in the triSurface.
Tobi
Old   January 31, 2011, 01:43
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Let me know how it works.
I've come up with a whole new algorithm and
I'm working on a complete re-write of this tool.
niklas is offline   Reply With Quote
Old   February 16, 2011, 07:28
Tobi's Avatar
Tobias Holzmann
Hi niklas,
i ve been working on a chtMultiRegion case and got very small and big mappedWall types.
Your tool is fantastic for that. without it i never get the interfaces correctly.
Its simple and good.
1. castellated (sHM)
2. snap (sHM)
3. snapEdge
(4. addLayers)
thats it
Great tool...
Here an picture.
Good work
Tobi
Old   February 24, 2011, 04:46
Default snapEdge
Hannes
Hanno is on a distinguished road
Hey Niklas,
im very interested in your work. You've got any further with your re-write?
And, most important: is there a way to run your tool in parallel? decomposePar + mpirun doesn't do the job
Hanno is offline   Reply With Quote
Old   February 24, 2011, 05:49
niklas's Avatar
Niklas Nordin
Originally Posted by Hanno View Post
Hey Niklas,
yes, but I need to clean it and make it more structured, otherwise I'm quite happy with the new
algorithm.
It works better I think.
N
Old   February 24, 2011, 06:33
Hannes
algorithm.
N
Please get me informed as soon as you have it ready to share. I try to mesh a pretty complex geometry (with only 90° angles) with SHM+SE but SE doesnt do the job so far.
Old   February 25, 2011, 07:46
niklas's Avatar
Niklas Nordin
Try this one and if it fails I'd like to look at your stl if its possible.
(Note that its no longer necessary to link the stl to from the constant/triSurface directory)
http://openfoam.nequam.se/cases/snapEdge_110225.tgz
Everyting is now in a separate class to make it easier for those who want to incorporate snapEdge
with snappy.
N
Old   February 26, 2011, 02:06
Fabian Braennstroem
braennstroem is on a distinguished road
Hi Niklas,
does this work in parallel as well!?
Best Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   February 26, 2011, 08:14
niklas's Avatar
Niklas Nordin
nope, it does not.
Old   February 26, 2011, 09:53
Fabian Braennstroem
thanks for the quick response.
Old   February 28, 2011, 06:55
Hannes
Hey Niklas,
thanks a lot, i'll give it a try and report results later!
Old   October 30, 2012, 10:09
hfs
hfs is on a distinguished road
with snappy.
N
Hello Niklas,
Thank you very much for providing the tool!
I have tried it with my STL .. did not really work for me
Please check my STL if you have time
and If you have more time please check my case under this link:
http://dl.dropbox.com/u/32336583/Case.zip
Thanks a lot!
hfs is offline   Reply With Quote
Old   October 31, 2012, 02:37
niklas's Avatar
Niklas Nordin
it looks like you are trying to 'snap' to a surface.
this tool only work on edges.
Old   October 31, 2012, 03:10
hfs
Exactly.
Could you please advice? I have tried to play around with snapping parameters ... I increased snapping iterations (5000 iterations) ... I have disabled all snapping controls ... nothing is working
Really appreciate your guidance!
Regards,
Old   October 31, 2012, 04:08
niklas's Avatar
Niklas Nordin
How do you get the Umb patch?
Old   October 31, 2012, 04:58
niklas's Avatar
Niklas Nordin
Does these work better?
File Type: gz blockMeshDict.gz (463 Bytes, 56 views)
Old   October 31, 2012, 05:34
hfs
Thanks for your quick reply
I got Umb patch from an STL file... this is what I did
1-Extracted the geometry from the STL and convert it to emesh using the command: surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/Umb.stl Umb
2-Duplicated edges in emesh (simply by copy-pasting) as recommended here (http://www.cfd-online.com/Forums/ope...rane-edge.html)
3-Converted this emesh file to faceZones by adding faceZone Umb; cellZone Umb; cellZoneInside inside; to snappyHexMeshDict as follows:
refinementSurfaces
Umb
// Surface-wise min and max refinement level
level (2 2);
faceZone Umb;
cellZone Umb;
4- After the SHM, I converted this faceZones into Patches using the command: createBaffles Umb '(Umb Umb)'
Old   October 31, 2012, 05:39
hfs
Wow!
Thank you very muchhh!!!
It is snapped very nicely! ...
Is this here the secret?: [faceType boundary;]
In blockMesh: Is creating one patch for all other patches as an empty patch is better for snapping?? Why??
Thanks again!
Old   October 31, 2012, 06:23
niklas's Avatar
Niklas Nordin
ok, thats good. I've been trying to get the edges to actually match also, but for some reason they wont.
I dont know why.
I dont have time to look into this now. If I do, ill post the solution here.
N
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
P1 and DT Radiation Model Failure Birnensuppe CFX 6 November 13, 2017 06:06
The fluent stopped and errors with "Warning: License server connection lost.poll: pro yuyuxuan FLUENT 4 January 9, 2014 05:20
snapEdge not working crossley90 OpenFOAM 4 August 4, 2011 04:26
[snappyHexMesh] snapEdge compilation problems rassilon OpenFOAM Meshing & Mesh Conversion 4 February 23, 2011 21:23
