[blockMesh] Blockmesh for swimming cylinder
Old   December 14, 2011, 10:25
Default Blockmesh for swimming cylinder
V.Vladov
v000v is on a distinguished road
Hallo,
I'm new here and i'm new with OpenFoam. So i work at simulation of swimming cylinder in waves. I've started to wright blockMeshDict file.
As reference for mesh generation i have took an example from ProgrammersGuide.pdf (openFoam parent dir. -->) page 47 ff..
So i want to see what i' ve done in Paraview, but there is a problem with block mesh. After typing in Terminal "blockMesh" from my case dir. i've got error that looks like:
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_d908cad1f0f5da63365b2a5dd0f6be17536ee27d/platforms/linux64GccDPOpt/lib/libcodeStream_d908cad1f0f5da63365b2a5dd0f6be17536e e27d.so"
file: /home/v000v/OpenFOAM/v000v-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/FLNG/constant/polyMesh/blockMeshDict from line 17 to line 17.
From function functionEntries::codeStream::execute(..)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 210.
FOAM exiting
Can anybody offer a solution for my problem?
v000v is offline   Reply With Quote
Old   December 15, 2011, 03:51
V.Vladov
Hallo again,
I've got a couple of problems under control, so I've change a little bit my blockMeshDict.
Now i've got another one. I think that the problem is in a mesh at the edge between cylindrical mesh and the rest. That the faces are not identical on the both sides of edge.
How can I assemble my mesh so that there are same face number on the both sides of the edge?
Should i calculate it by side and arrange my mesh there for, or is there some skripts or other tricks to get the mesh works?
Thanks!
Old   December 21, 2011, 07:30
V.Vladov
Hallo again,
I've got my mesh to view. I have a problem with a boundary conditions in the mesh. "Down" should be my symmetry plane, so I have define all faces in this plane. Terminal massage says that a couple of them have no neighbor cell.
If i write these faces as comment, then turns openFoam in Paraview these faces to default faces and this pretty ugly.
So can anybody take a look at my Mesh and explain me what the case is?
Thank you guys.
Old   December 21, 2011, 07:59
Martin
MartinB will become famous soon enough
there were four minor problems, their correction marked with "// <---".
Should work now.
Martin
MartinB is offline   Reply With Quote
Bernhard
Bernhard is on a distinguished road
Probably your facelist for some patches is not complete. Boundary faces that are not assigned to a patch form a seperate patch. This is probably what happened here.
Bernhard is offline   Reply With Quote
Old   December 21, 2011, 08:22
V.Vladov
Originally Posted by MartinB View Post
Should work now.
Martin
Thanks, work's fine!
P.S. too much points and blocks to hold overview. Thank you!
[blockMesh] blockMesh cylinder with two inlets cfd4res OpenFOAM Meshing & Mesh Conversion 4 March 9, 2018 12:02
[blockMesh] Hole in a cylinder / T-junction of two cylinders using blockMesh anuragm OpenFOAM Meshing & Mesh Conversion 4 March 2, 2018 08:36
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
