[blockMesh] pipe bend mesh imperfect
Like Tree1Likes
  • 1 Post By jochemvandenbosch
Old   December 16, 2011, 10:13
Default pipe bend mesh imperfect
Jochem van den Bosch
jochemvandenbosch is on a distinguished road
Dear fellow Foamers,
I'm still sort of a newbie in OpenFOAM and I'm trying to mesh a pipe bend in blockMesh. I've got no errors when I run blockMesh (and checkMesh) but for some reason the diameter of the bend seems smaller than the diameter of the rest of the pipe. I've checked every node and block like 5 times and everything seems to be in order. Does anybody see what mistake(s) I made? Thanks in advance! This is my blockMeshDict (in the attachment a picture of my mesh in paraFoam)
| \\ / O peration | Version: 1.3 |
| \\ / A nd | Web: http://www.openfoam.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
// pipe horizontal
(0 0 0) // 0
(1 0 0) // 1
(1 0.12 0) // 2
(0 0.12 0) // 3
(0 0 0.12) // 4
(1 0 0.12) // 5
(1 0.12 0.12) // 6
(0 0.12 0.12) // 7
// bend region
(1.34 0 -0.34) // 8
(1.46 0 -0.34) // 9
(1.46 0.12 -0.34) // 10
(1.34 0.12 -0.34) // 11
// pipe vertical
(1.34 0 -1.34) // 12
(1.46 0 -1.34) // 13
(1.46 0.12 -1.34) // 14
(1.34 0.12 -1.34) // 15
// cylinder nodes
(0 -0.01071 -0.01071) // 16
(0 0.13071 -0.01071) // 17
(0 0.13071 0.13071) // 18
(0 -0.01071 0.13071) // 19
(1 -0.0107 -0.01071) // 20
(1 0.13071 -0.01071) // 21
(1 0.13071 0.13071) // 22
(1 -0.01071 0.13071) // 23
(1.32929 -0.01071 -0.34) // 24
(1.47071 -0.01071 -0.34) // 25
(1.47071 0.13071 -0.34) // 26
(1.32929 0.13071 -0.34) // 27
(1.32929 -0.01071 -1.34) // 28
(1.47071 -0.01071 -1.34) // 29
(1.47071 0.13071 -1.34) // 30
(1.32929 0.13071 -1.34) // 31
blocks
// inlet block
hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1)
hex (4 5 6 7 19 23 22 18) (10 10 10) simpleGrading (1 1 1)
hex (3 2 21 17 7 6 22 18) (10 10 10) simpleGrading (1 1 1)
hex (16 20 21 17 0 1 2 3) (10 10 10) simpleGrading (1 1 1)
hex (16 20 1 0 19 23 5 4) (10 10 10) simpleGrading (1 1 1)
// bend block
hex (1 8 11 2 5 9 10 6) (10 10 10) simpleGrading (1 1 1)
hex (5 9 10 6 23 25 26 22) (10 10 10) simpleGrading (1 1 1)
hex (2 11 27 21 6 10 26 22) (10 10 10) simpleGrading (1 1 1)
hex (20 24 27 21 1 8 11 2) (10 10 10) simpleGrading (1 1 1)
hex (20 24 8 1 23 25 9 5) (10 10 10) simpleGrading (1 1 1)
// outlet block
hex (12 13 14 15 8 9 10 11) (10 10 10) simpleGrading (1 1 1)
hex (13 29 30 14 9 25 26 10) (10 10 10) simpleGrading (1 1 1)
hex (15 14 30 31 11 10 26 27) (10 10 10) simpleGrading (1 1 1)
hex (28 12 15 31 24 8 11 27) (10 10 10) simpleGrading (1 1 1)
hex (28 29 13 12 24 25 9 8) (10 10 10) simpleGrading (1 1 1)
edges
// cylinder 1
arc 16 17 (0 0.06 -0.04)
arc 17 18 (0 0.16 0.04)
arc 18 19 (0 0.06 0.16)
arc 19 16 (0 -0.04 0.06)
// cylinder 2
arc 20 21 (1 0.06 -0.04)
arc 21 22 (1 0.16 0.04)
arc 22 23 (1 0.06 0.16)
arc 23 20 (1 -0.04 0.06)
// cylinder 3
arc 24 25 (1.4 -0.04 -0.34)
arc 25 26 (1.5 0.06 -0.34)
arc 26 27 (1.4 0.16 -0.34)
arc 27 24 (1.3 0.06 -0.34)
// cylinder 4
arc 28 29 (1.4 -0.04 -1.34)
arc 29 30 (1.5 0.06 -1.34)
arc 30 31 (1.4 0.16 -1.34)
arc 31 28 (1.3 0.06 -1.34)
// bend
arc 1 8 (1.24041 0 -0.09958)
arc 5 9 (1.32527 0 -0.01473)
arc 2 11 (1.24041 0.12 -0.09958)
arc 6 10 (1.32527 0.12 -0.01473)
arc 20 24 (1.23284 -0.01071 -0.10716)
arc 21 27 (1.23284 0.13071 -0.10716)
arc 23 25 (1.33284 -0.01071 -0.00715)
arc 22 26 (1.33284 0.13071 -0.00715)
patches
patch inlet
(4 7 3 0)
(19 18 7 4)
(7 18 17 3)
(0 3 17 16)
(19 4 0 16)
patch outlet
(12 15 14 13)
(28 31 15 12)
(15 31 30 14)
(13 14 30 29)
(28 12 13 29)
wall walls
(19 23 22 18)
(17 18 22 21)
(16 17 21 20)
(23 19 16 20)
(20 21 27 24)
(21 22 26 27)
(23 25 26 22)
(23 20 24 25)
(24 27 31 28)
(27 26 30 31)
(26 25 29 30)
(25 24 28 29)
mergePatchPairs
gchamma likes this.
jochemvandenbosch is offline   Reply With Quote
Old   December 19, 2011, 08:28
Nobody? I'm drawing a blank here...
Old   December 20, 2011, 23:58
Lachlan Graham
Locky3827 is on a distinguished road
i had this issue. I got around it by meshing the bend itself in three stages. I suspect it might be blockMesh not taking account of the curvature between the straight pipes.
Regards,
Locky
Locky3827 is offline   Reply With Quote
Old   December 21, 2011, 04:42
How do you mean 'meshing the bend itself in three stages'. I'm afraid I don't fully understand. Could you clarify it a little.
Best regards,
Old   December 21, 2011, 17:10
Lachlan Graham
What I mean is that for a 90 degree bend, split that up into say 3x 30 degree segments instead of a single 90 degree bend. The mesh looks better as a result.
Old   December 22, 2011, 03:52
Hi Locky, I think splitting up the bend will indeed make the mesh look better. However, eventually I want to make a spiraling pipe and if I divide every corner in 3 segments this will be a immense job. Another forum user suggested defining the outermost lines of the corners (which I didn't in my mesh). I think this is the solution to the problem!
Best regards and thank you for your help!
Old   February 16, 2012, 16:50
Default Question about your case
ChemE1989 is on a distinguished road
I am VERY new to OpenFoam and I have been trying to model a case that is similar to yours. I am having difficulties with the boundary file in polyMesh. Can anyone shed some light on what startFace is and how to calculate the value for it? Would anyone be able to share how the code looks like for this case?
Thanks
ChemE1989 is offline   Reply With Quote
Old   February 17, 2012, 03:50
Dear ChemE1989, you don't need to do anything with the 'boundary' file in polymesh. This file is automatically generated when you run 'blockMesh' in terminal on the blockMeshDict file. If you need a example blockMeshDict file of a bend, just send me a message.
Best regards,
Old   November 1, 2012, 03:03
kjetil is on a distinguished road
Best regards,
I believe this is a known problem, when generating large bends: http://www.cfd-online.com/Forums/ope...rved-bend.html.
kjetil is offline   Reply With Quote
Old   November 12, 2014, 04:49
Default vertical, horizontal and bent pipe in openfoam
Yapi
YellowSimulator is on a distinguished road
Hello every one. Could some one tell me how to find a tutorial on how to construct a vertical, horizontal and bend pipe with blockmesh in openFoam.
Thank you in advance.
YellowSimulator is offline   Reply With Quote
[mesh manipulation] extrudeMesh for pipe bend cfd4res OpenFOAM Meshing & Mesh Conversion 0 March 15, 2018 13:04
[GAMBIT] 3D Two pipe T-shape junction mesh Jing ANSYS Meshing & Geometry 8 April 26, 2013 12:27
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[blockMesh] generate a graded pipe mesh. jenright OpenFOAM Meshing & Mesh Conversion 0 August 22, 2009 08:58
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
