December 20, 2011, 16:16 |
3D Meshing Ideas?
Patrick Pazour
Rep Power: 14 |
Dear Forum Users!
After completing some simple meshing tasks with gmsh (2.2.6) and discretizer, I will do some more realistic meshing cases. I have to use this old gmsh version, otherwise there is no chance for me to convert it via gmshToFoam (OpenFOAM 1.5-Dev). The next case will be a more realistic variant of my hotgas nozzle (inert gas). We have different wall temperatures and an inlet pipe, which is normal to the main pipe. Later on, I wanna take a turbulent heat transfer solver. For a better imagination, I attached two images of the 3D part (ProEngineer). For the first try I exported it as a .stl The colored surfaces represent the intended boundary layers:
My experience with snappyHexMesh is ... not the best. I dont know how to define the boundary layers and there are problems with "sharp" edges. Maybe there is a way with the discretizer... Importing the .stl in gmsh 2.2.6 works really good, but I dont have an idea how to create the 3D mesh with this version. So, do you have some ideas, how to get a mesh out of the 3D model for the upcoming case. Thanks in advance Edit: Just work around with Pointwise and updated the 3D model to be more ... fluent I split the geometry in a rear part with the intersection, and a front part with the nozzle, if someone have experience with this kind of meshing, help is welcome Last edited by Artex85; December 22, 2011 at 15:17. Reason: Another Mesher, 3D Model update |
December 28, 2011, 08:14 |
Its going on
Patrick Pazour
Rep Power: 14 |
Nozzle Version 2 - see last post:
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
[ANSYS Meshing] Cooper Method Meshing | RTN3000 | ANSYS Meshing & Geometry | 1 | March 1, 2015 23:59 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
