[mesh manipulation] Generating Mesh from LiDAR data (PointCloud or Surface) |
January 15, 2012, 17:28 |
Ken Mankoff
Rep Power: 15 |
I'm fairly new to OpenFOAM and just beginning to make my own experiments and meshes. I have data collected with a LiDAR that is in pointcloud format (PLY, PCD). I can convert it easily to a gridded format using the opensource Points2Grid tool. I would like to be able to use this as one wall of my simulation. It does not seem that there is much overlap between the LiDAR and CFD. Has anyone done something similar, or have pointers or know of tools that can take a pointcloud and generate a mesh from it? Thanks, -k. |
February 1, 2012, 09:53 |
Rep Power: 14 |
What do you want to do exactly ?
You have coordinates in space corresponding to the points where your Lidar is taking measurements ? And you want to create a mesh from this ? its not clear .. |
February 1, 2012, 09:58 |
Ken Mankoff
Rep Power: 15 |
Correct. I have (x,y,z) triplets in space from LiDAR. I'd like to create a mesh from this.
February 1, 2012, 10:07 |
Niklas Nordin
Rep Power: 29 |
if you can convert it to an STL it sounds pretty similar as the snakeriver tutorial.
February 1, 2012, 10:10 |
Ken Mankoff
Rep Power: 15 |
Yes. Any suggestions on free tools that convert point clouds to STL?
February 1, 2012, 10:33 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
You could try to find a delaunay-triangulation tool. Having the triangles you should be able to write the STL yourself. With a delaunay-triangulation you will also have the best estimate of the surface between the measured points. I believe matlab uses/used qhull, which is an open-source delaunay bundle. Best regards, Niels |
February 1, 2012, 11:24 |
#7 | |
Rep Power: 14 |
Why don't you create a mesh around these points, a cube for example, and then refine ? Do you have the topography ? |
February 1, 2012, 12:41 |
Rep Power: 17 |
If you can't find a better tool, there are MATLAB scripts in the web that you can use to convert point data into stl format.
February 2, 2012, 05:14 |
#9 |
February 2, 2012, 06:09 |
#10 |
BastiL
Rep Power: 20 |
lidar, mesh conversion |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
Interpolating volume data onto quad surface mesh | N.R. | CFX | 6 | June 7, 2007 08:15 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
