[Gmsh] gmshToFoam
Old   March 15, 2012, 17:21
Default gmshToFoam
Matteo
matteogir is on a distinguished road
Ho everybody!
I am a complete newby in the world of CFD and OpenFoam + gmsh in particular.
For this reason i am trying with tutorial files. First i try to solve a demo file of openfoam and all is working fine; then i 've tried with a demo file taken from gmsh with extension .geo ; i have created in a total automatic way the mesh file with extension msh; now i would like to convert it, but i don't know how to do and all my trials have gone bad.
I have created the folders as requested, in particular "constant" and "system". Inside "constant" i have created "polyMesh" and inside system i have put the files controlDict fvschemes and fvSolutions. Now i don't know exactly where i have to put my msh file, but i have tried in almost all the locations. When I call the funciton gmshToFoam i get this kind of error. May anyone help me? Thank you very much for your help.
--> FOAM Warning : Not using gmsh face 3(5937 6138 6114) since zero vertex is not on boundary of polyMesh
FaceZones:
Zone Size
0 12310
Writing zone 0 to cellZone cellZone_0 and cellSet
Writing zone 0 to faceZone faceZone_0 and faceSet
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/gmshToFoam"
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Segmentation fault
matteogir is offline   Reply With Quote
Old   July 9, 2012, 05:12
T.D. is on a distinguished road
HI,
what you can do, is simply take an original case Folder example, lets say the "cavity" test case from icoFoam tutorials or any other one.
Then you just place your .msh file directly inside the "cavity" Folder, then you do "gmshToFoam". It should be OK (don't forget to include for physical surfaces and volume in your mesh inside gmsh). Good Luck
T.D. is offline   Reply With Quote
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 10:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 03:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 07:36
