[Other] how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM?
Like Tree1Likes
  • 1 Post By anon_a
Old   March 17, 2012, 10:56
Exclamation how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM?
ashkan
dictatore_bozorg is on a distinguished road
Hello
i need to run a direct numerical simulation for my research on Zero Pressure Gradient (ZPG) Turbulent Boundary Layer (TBL) on a plate.
i find that perhaps i can do this with dnsFoam in OpenFOAM.
but i am beginner in OpenFOAM, i run dnsfoam from tutorial but when i want change the mesh size from 16*16*16 to for example 32*32*32 and run the solver by type dnsFoam in terminal below error appeared.
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : dnsFoam
Date   : Mar 17 2012
Time   : 18:52:22
Host   : "ubuntu"
PID    : 5381
Case   : /home/ashkan/OpenFOAM/ashkan-2.1.0/run/DNS/dnsFoam/boxTurb16
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh, no clear-out for time = 0
Reading transportProperties
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
size 4096 is not equal to the given value of 32768
file: /home/ashkan/OpenFOAM/ashkan-2.1.0/run/DNS/dnsFoam/boxTurb16/0/U from line 18 to line 4146.
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
please help me and if possible tell me what can i do?
dictatore_bozorg is offline   Reply With Quote
Old   March 17, 2012, 11:29
Disabled
anon_a is on a distinguished road
If you look at this file (where you see the boundary and initial conditions for U), you will see 4096 (16x16x16) initial values for U. Since the mesh is changed, the fields will have to be adjusted to this modification. You need to use the utility mapFields (you should find information in this forum but also in the manual if I am not mistaken, in the cavity example).
And read the manual again. :-)
dictatore_bozorg likes this.
anon_a is offline   Reply With Quote
Old   May 15, 2012, 05:09
Default Solution
Mahdi Hosseinali
anishtain4 is on a distinguished road
anon_a's diagnosis was right, but there is a really easier way to solve it. This case is being initialized with boxTurb, not by mapFields or else.
Go to root/0 directory, open U file and change the internalField nonuniform bla bla to internalField uniform (0 0 0); then run the boxTurb utility and you're good to go
anishtain4 is offline   Reply With Quote
Old   October 9, 2015, 05:08
Default Boundary Layer DNS using dnsFoam?
Malik
malik.mdb is on a distinguished road
Did you modify the code dnsFoam for zpg boundary layer flow? dnsFoam is for isotropic turbulence.
malik.mdb is offline   Reply With Quote
dns, dnsfoam, tbl, zpg
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Developed turbulent boundary layer simulation on flat plate Turbulent CFX 3 June 8, 2015 19:46
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
