[mesh manipulation] OpenFoam 2.1.0/x: creation of sets and cellZones.
Like Tree44Likes
Old   March 31, 2012, 19:49
Default OpenFoam 2.1.0/x: creation of sets and cellZones.
Elh. A2. BAH
ebah6 is on a distinguished road
Dear all,
I exported a mesh to OpenFoam and the files I got are: boundary, faces, neighbour, owner and points.
How can I proceed to create cellZones to define rotating parts?
I saw that earlier versions have cellSet utilities which I can not find.
Can anyone help on this issue?
Thank you all.
ebah6 is offline   Reply With Quote
Old   March 31, 2012, 21:37
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Originally Posted by ebah6 View Post
Dear all,
Thank you all.
CellSet have been replaced by setSet
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   March 31, 2012, 22:13
Elh. A2. BAH
Thanks Sail,
Can you please elaborate on how to use this feature.
I did try to utilise it but doesn't require that a set exists in the constant/polyMesh/sets directory?
So how would go along from the primary faces, points, etc. files to that that set then to the cellZones?
Thanks very much for your time.
Old   March 31, 2012, 23:27
Elh. A2. BAH
Hello Vieri,
I think I get how to do it.
Again, thank you.
saadouda likes this.
Old   April 1, 2012, 09:20
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Hello Vieri,
Again, thank you.
Dear ebah6
Could you please help me how setSet is working, please?
I am looking at the the Openfoam tutorial files for chtMultiRegionFoam and they used the same utility. but i can not understand how it is working.
i was thinking that for specifinng a part of mesh as new one , i need to input the number of grids or the coordinates
Best Mehdi
mm.abdollahzadeh is offline   Reply With Quote
Old   April 1, 2012, 10:57
Nima Samkhaniani
nimasam is on a distinguished road
send me a private message contains your email to send you a tutorial in persian
s.m, ali-group and saadouda like this.
nimasam is offline   Reply With Quote
Old   April 1, 2012, 18:44
Elh. A2. BAH
Originally Posted by mm.abdollahzadeh View Post
Dear ebah6
Best Mehdi
Hello Mehdi,
I just did it on a dummy example for to see first how to get it.
So consider the following:
setSet
faceSet f0 new patchToFace bc_patch
cellSet c0 new faceToCell f0 any
cellZoneSet c0 new setToCellZone c0
Note: bc_patch is the boundary that you want to use for the cellZone.
Hope this helps.
Old   April 1, 2012, 19:13
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
I think you could also use topoSet instead of setSet.
I tried both of them and I got the same result. The only difference is that topoSet seems to be easier to use…
vs1 likes this.
lovecraft22 is offline   Reply With Quote
Old   April 2, 2012, 10:56
mahdi abdollahzadeh
thanks all
I understand how setSet utility is working .
today i tried to test a case with chtMultiregionFoam.
my case includes natural convection in an enclosure with a block at the bottom. the bottom surface of block was heated.
the strange thing is that the temperature is not passing throgh solid zone to fluid zone. I am using turbulentTemperatureCoupledBaffleMixed as the boundary condition on the interface of soid and liquid zone.
I thinck there should be sth related to boundary condition. I will be too much thankful to recive you oponions .
Best
Mehdi
Old   April 2, 2012, 11:39
Elh. A2. BAH
thanks all
Best
Mehdi
I fear I do not know about this issue; I am beginner.
Hope someone can help.
Regards.
Old   April 10, 2012, 06:16
Samuele Z
samiam1000 is on a distinguished road
Hi All,
I would need help about using the topoSet feature.
I have a .msh mesh imported from Fluent. I give the fluent3DMeshToFoam command and I have a cell zones (in the cellZone file!).
Which is the right topoSetDict in order to be able to run chtMultiRegion properly?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   April 10, 2012, 07:01
mahdi abdollahzadeh
Dear all
I don't know how to work with toposet. but the easiest way in my opinion is to export your mesh from fluent to openfoam. if you have just one interface between your solid and interface zone . just create the different zones in gambit and after exporting your grid use
runApplication fluentMeshToFoam name.msh -writeSets
runApplication setsToZones -noFlipMap
runApplication splitMeshRegions -cellZones -overwrite
but if you have a more complicated situation. for example that you have a block in the steam of fluid and half of th block surface is insulated and the other half is conductive. if you use the above command you will have just one interface and you can not be able to define different boundary condition. but instead you can create the mesh of different zones separately in gambit and export them separately to openfoam and place them in the folders with name of zones. then if u want conjugate heat transfer at an interface use this boundary condition other wise use other boundary condition:
**** it is the boundary in solid zone
heater_to_surrondingAir2
type compressible::turbulentTemperatureCoupledBaffleMix ed;
neighbourFieldName T;
K solidThermo;
KName none;
value uniform 300;
* it is the boundary in fluid zone
surrondingAir_to_heater2
K basicThermo;
KName none;
value uniform 300;
CROS, Mojtaba.a, jiaojiao and 2 others like this.
Old   April 10, 2012, 09:26
Samuele Z
When I give the
I get this error:
lab@lab-laptop:~/Documenti/cases_OF/OF_case11_test$ splitMeshRegions -cellZones -overwrite
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : splitMeshRegions -cellZones -overwrite
Date   : Apr 10 2012
Time   : 14:11:09
Host   : "lab-laptop"
PID    : 5028
Case   : /home/lab/Documenti/cases_OF/OF_case11_test
nProcs : 1
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:5
Writing region per cell file (for manual decomposition) to "/home/lab/Documenti/cases_OF/OF_case11_test/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/lab/Documenti/cases_OF/OF_case11_test/0/cellToRegion"
Region	Cells
0	15450
1	9450
2	81885
3	2940
4	54675
Region	Zone	Name
0	0	door
1	4	roof
2	2	internal_air
3	3	infinite_air
4	1	external_air
Sizes of interfaces between regions:
Interface	Region	Region	Faces
0		3	4	420
1		0	1	150
2		1	2	795
3		0	4	1545
4		0	2	1545
5		1	4	1095
Reading volScalarField Ypmma
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
    patch type symmetryPlane and patchField type calculated
file: /home/lab/Documenti/cases_OF/OF_case11_test/0/Ypmma::boundaryField::.* from line 25 to line 26.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 164.
FOAM exiting
Any idea?
Old   April 10, 2012, 09:30
mahdi abdollahzadeh
i am not sure but I guess sth,
you may have putted some dictionys for your variables in 0 folder which are not empty.
may be the problem is related that.
Old   May 15, 2012, 07:51
Default compressible::turbulentTemperatureCoupledBaffle
  #15
namdar
Budlo is on a distinguished road
Hi dear
I want set a boundary condition for conjugate boundary in chtMultiRegionFoam.
But I dont find any information about this.
What boundary condition we can set for conjugate boundary? (please discribe it)
Budlo is offline   Reply With Quote
Old   May 21, 2012, 14:15
mahdi abdollahzadeh
Dear namdar
As i know you can use
K basicThermo;
KName none;
value uniform 300;
for conjucate heat transfer....
K is the name of your diffusity
Old   May 22, 2012, 03:03
namdar
Why we use uniform value(300) in conjugate B.C ? (the conjugate boundary must to be solve)
What is diferent between: Compressible::turbulentTemperatureCoupledBaffleMix ed,
Compressible::turbulentTemperatureCoupledBaffle,
Old   May 22, 2012, 03:04
Samuele Z
Dear mm.abdollahzadeh,
does this allow you to have 2 fluid regions that have a coincident interface?
Old   May 23, 2012, 07:51
namdar
Hi All
1-Why we use uniform value(300) in conjugate B.C ? (the conjugate boundary must to be solve)
2- In chtMultiRegionFoam in OpenFoam 2011:
What is Ychar and Ypmma files in boundary condition ?
samiam1000 likes this.
Old   June 17, 2012, 20:40
Jie
jiejie is on a distinguished road
Dear foamers
For those who are doing rotating mesh with AMI. I have summarized the procedures after I received the advice from ebah6. I was using GGI from the OF1.6-ext and the procedure was a bit different in the OF2.1.x.
Since I am using ICEM for the mesh, I created a rotor zone (an inner-cycliner) inside a stator zone (a hollow cylinder around the rotor zone). The interfaces between the rotor zone and the stator zone are defined as AMI1 and AMI2 (AMI1=AMI2, I am not sure whether you can leave a tiny gap in between as the old GGI requires a small gap in between). Save the mesh as fluent format.
1. use fluent3DMeshToFoam to convert the icem mesh to openfoam compatible.
2. set up the AMI boundaries under case/constant/boundary:
AMI_1
type cyclicAMI;
nFaces 17893;
startFace 721902;
matchTolerance 0.0001;
neighbourPatch AMI_2;
transform noOrdering;
AMI_2
type cyclicAMI;
nFaces 6844;
startFace 741999;
neighbourPatch AMI_1;
3. Create Sets and cellZones (here is what I received from ebah6):
Suppose that your rotating block is comprised within a cylinder of axis z and that the points of intersection of this axis with the bases of the cylinder are (0 0 0) and (0 0 1); and your cylinder radius is 0.5.
All you need in such a case is to use the setSet command as follows: only that which is between quotes without the quotes.
0) type "setSet" from your case directory.
1) "cellSet c0 new cylinderToCell (0 0 0) (0 0 1) 0.5"
2) "cellZoneSet c0Zone new setToCellZone c0"
your rotating zone will be c0Zone.
by the way, c0 ans c0Zone are just made-up names, you can choose your own.
I think the simulation is ready to go now. Hopefully this is handy to whoever whats to use AMI.
Jie
wyldckat, Blanco, Soheyl and 15 others like this.
jiejie is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
