[snappyHexMesh] Some problems about using snappyHexMesh |
xiaoweii
Rep Power: 14 ![]() |
Hello everybody,
I just started to use snappyHexMesh and tried to test some existed applications in OpenFOAM-2.1.0 to be familiar with the use of snappyHexMesh. The directory is "./tutorials/incompressible/simpleFoam/turbineSiting/". I run some commands according to "Allrun". Firstly "blockMesh", then "cp system/decomposeParDict-nonPar system/decomposeParDict", then "decomposePar", then "cp system/decomposeParDict-par system/decomposeParDict", then "mpirun -np 2 snappyHexMesh -parallel -overwrite". The execution didn't finish and got stuck as below: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0-snappy | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : snappyHexMesh Date : Apr 09 2012 Time : 16:16:32 Host : "ln0" PID : 24934 Case : /vol6/home/test605/OpenFOAM/OpenFOAM-2.1.0-snappy/tutorials/incompressible/simpleFoam/turbineSiting-bak nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.23 s Overall mesh bounding box : (581321 4785370 930) (582290 4786240 1500) Relative tolerance : 1e-06 Absolute matching distance : 0.00142153473401 Reading refinement surfaces. Read refinement surfaces in = 0.11 s Reading refinement shells. Refinement level 6 for all cells inside windTurbine1 Refinement level 6 for all cells inside windTurbine2 Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 56100 Number of edges to retest : 56100 Obviously the execution didn't finish. Does anyone know how to solve this problem? Thank you! |
sorry misread the bounding box..
why is it so far from the origin? Last edited by matt.mech.eng; April 13, 2012 at 05:58. Reason: my mistake |
snappyhexmesh parallel |
[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh | scareneb | OpenFOAM Meshing & Mesh Conversion | 2 | August 13, 2014 07:13 |
[snappyHexMesh] snappyHexMesh problems 1.5->1.6 | grtabor | OpenFOAM Meshing & Mesh Conversion | 5 | May 18, 2012 03:00 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
[snappyHexMesh] SnappyhexMesh and Symmetryplane | bastil | OpenFOAM Meshing & Mesh Conversion | 10 | October 7, 2008 17:07 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
