Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Change of Bug-Tracker for openfoam-extend
Old   June 18, 2014, 16:17
Default Change of Bug-Tracker for openfoam-extend
Assistant Moderator
Bernhard Gschaider
Hi!
Sourceforge will discontinue its support for the Mantis-Bugtracker on the 19th of June. This means that https://sourceforge.net/apps/mantisb...?page_number=1 will no longer be available.
Sourceforge has provided a migration path and will provide backups of the last state of Mantis. Using these backups we will set up new bug-trackers on https://sourceforge.net/projects/ope...urce=directory . The procedure has been tested and no essential data from Mantis (including attachments) will be lost. Bug IDs will be the same but the URLs will change.
Once the transition is finished (which should take less than a day) it will be announced here.
This affects (amongst others) the bug-trackers for
- foam-extend
- swak4Foam
- PyFoam
- waves2foam
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
SnappyHexMesh bug or dict syntax change wikstrom OpenFOAM Bugs 2 January 13, 2009 12:47
Bug in layerAdditionRemoval change to OF15 mesh format andersking OpenFOAM Bugs 2 August 6, 2008 04:17
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Bug in the DEFINE_ADJUST macro? Senthil FLUENT 5 September 3, 2002 22:26
