Exporting Face Normal of a patch and some other values |
October 25, 2012, 13:32 |
HECKMANN Frédéric
Rep Power: 16 |
Dear all,
I want to do a post processing process of a patch (wall) where I need: - Face center coordinate - Normal to Face vector - Face area - Other data like density 1) I have tried first with a sampling but I cannot find a field "name" to get the face properties. Is it possible to get such a thing ? Here I put a "mesh.Sf()" as example of what I want. Code:
interpolationScheme cellPointFace; surfaceFormat raw; setFormat raw; surfaces ( wallTest { type patch; patches (wall); interpolate true; triangulate false; } ); fields ( rho U mesh.Sf() ); Code:
label wallPatch = mesh.boundaryMesh().findPatchID("wall"); rho.boundaryField()[wallPatch] // Density U.boundaryField()[wallPatch] // Velocity mesh.Sf().boundaryField()[wallPatch] // Face normal vector mesh.Cf().boundaryField()[wallPatch] // Face Center mesh.magSf().boundaryField()[wallPatch] // Face magnitude // "Export" data in the consol Info<< U.boundaryField()[wallPatch] << endl; |
October 26, 2012, 05:46 |
Daniel P. Combest
For the face centers on the patches, try something like
const fvPatchList& patches = mesh.boundary(); const surfaceVectorField& faceCenters = mesh.Cf(); scalar px; scalar py; scalar pz; forAll(patches,patchi){ label nFaces = mesh.boundaryMesh()[patchi].size(); for(int facei = 0 ; facei<nFaces, facei++){ px = faceCenters.boundaryField()[patchi][facei].x() py = faceCenters.boundaryField()[patchi][facei].x() pz = faceCenters.boundaryField()[patchi][facei].x() } } Edit: the next solution seems much more elegant Last edited by chegdan; October 26, 2012 at 06:39. |
October 26, 2012, 05:54 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Heckmann,
The OpenFoam-formatted output can be achieved in the following way: Code:
IOField<vector> cfOut ( IOobject ( "cf", mesh.time().timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh.Cf().boundaryField()[ patchID ] ); cfOut.write(); Kind regards, Niels |
October 26, 2012, 06:38 |
HECKMANN Frédéric
Rep Power: 16 |
Thank you for yours answer
@chegdan Your function does something very similar to mesh.Cf().boundaryField()[wallPatch] but with each component separably. My question is more about how to export those data to a file in a convenient way. I don't really know how OpenFoam manage to write things on the hard drive. @ngj Your solution looks perfect ! I didn't know that we can use such direct coding into the solver. I will try your method this weekend and study the IOField. Thanks guys. (I'm still open to any other method) |
October 26, 2012, 06:49 |
Rep Power: 37 |
P.S. You could also add an if-statement around the above code, which looks like this
if ( runTime.write() ) { // The code above } / Niels |
November 9, 2012, 09:56 |
#6 | |
Albert Tong
Rep Power: 15 |
Hi Niels,
Greetings. Can you please enlighten me on how to output the pressure integration along a slice of any patch. I would like to solve the sectional force along a certain structure. Thanks in advance! Kind regards, Albert Quote:
Kind regards, Albert |
March 14, 2014, 07:44 |
Samuele Z
Rep Power: 18 |
Hi All,
I am interested in such a problem. I have a patch called "airfoil" and I would like to write the normals to each face on the patch in a text file. Do you know how I can get this? Thanks a lot, Samuele |
May 9, 2016, 18:28 |
Ishmael
Hi Niels, with regards to the block of code you wrote above , does it have to be in the creatFields header file for the output to be exported for post processing. Or can it still be added in the main function of the solver. I will appreciate your help
